[GRASS-dev] [GRASS-SVN] r66823 - grass/trunk/vector/v.in.lidar
Anna Petrášová
kratochanna at gmail.com
Thu Nov 12 15:11:27 PST 2015
On Thu, Nov 12, 2015 at 6:07 PM, Martin Landa <landa.martin at gmail.com>
wrote:
> Hi,
> 2015-11-12 23:51 GMT+01:00 <svn_grass at osgeo.org>:
> > Author: wenzeslaus
> > Date: 2015-11-12 14:51:02 -0800 (Thu, 12 Nov 2015)
> > New Revision: 66823
> > Modified:
> > grass/trunk/vector/v.in.lidar/main.c
> > Log:
> > v.in.lidar: import points only in selected areas [news]
> I like your idea (if I understand well, it's a tag which should help
> us to collect release news). I would suggest also to other devs to use
> it. Martin
Yes, it is great idea, I think Martin you came up with it couple of months
ago:-)
> > --- grass/trunk/vector/v.in.lidar/main.c 2015-11-12 22:28:39 UTC
> (rev 66822)
> > +++ grass/trunk/vector/v.in.lidar/main.c 2015-11-12 22:51:02 UTC
> (rev 66823)
> > @@ -113,11 +113,13 @@
> > struct GModule *module;
> > struct Option *in_opt, *out_opt, *spat_opt, *filter_opt, *class_opt;
> > struct Option *id_layer_opt, *return_layer_opt, *class_layer_opt;
> > + struct Option *vector_mask_opt, *vector_mask_field_opt;
> > struct Option *skip_opt, *preserve_opt, *offset_opt, *limit_opt;
> > struct Option *outloc_opt;
> > struct Flag *print_flag, *notab_flag, *region_flag, *notopo_flag;
> > struct Flag *nocats_flag;
> > struct Flag *over_flag, *extend_flag, *no_import_flag;
> > + struct Flag *invert_mask_flag;
> > char buf[2000];
> > struct Key_Value *loc_proj_info = NULL, *loc_proj_units = NULL;
> > struct Key_Value *proj_info, *proj_units;
> > @@ -155,12 +157,12 @@
> > unsigned long long n_features; /* what libLAS reports as point
> count */
> > unsigned long long points_imported; /* counter how much we have
> imported */
> > unsigned long long feature_count, n_outside,
> > - n_filtered, n_class_filtered, not_valid;
> > + n_outside_mask, n_filtered, n_class_filtered, not_valid;
> > #else
> > unsigned long n_features;
> > unsigned long points_imported;
> > unsigned long feature_count, n_outside,
> > #endif
> > int overwrite;
> > @@ -227,6 +229,18 @@
> > "If not specified, all points are
> imported.");
> > class_opt->guisection = _("Selection");
> > + vector_mask_opt = G_define_standard_option(G_OPT_V_INPUT);
> > + vector_mask_opt->key = "mask";
> > + vector_mask_opt->required = NO;
> > + vector_mask_opt->label = _("Areas where to import points");
> > + vector_mask_opt->description = _("Name of vector map with areas
> where the points should be imported");
> > + vector_mask_opt->guisection = _("Selection");
> > + vector_mask_field_opt = G_define_standard_option(G_OPT_V_FIELD);
> > + vector_mask_field_opt->key = "mask_layer";
> > + vector_mask_field_opt->label = _("Layer number or name for mask
> option");
> > + vector_mask_field_opt->guisection = _("Selection");
> > skip_opt = G_define_option();
> > skip_opt->key = "skip";
> > skip_opt->type = TYPE_INTEGER;
> > @@ -283,6 +297,11 @@
> > region_flag->guisection = _("Selection");
> > region_flag->description = _("Limit import to the current region");
> > + invert_mask_flag = G_define_flag();
> > + invert_mask_flag->key = 'i';
> > + invert_mask_flag->description = _("Invert mask when selecting
> points");
> > + invert_mask_flag->guisection = _("Selection");
> > extend_flag = G_define_flag();
> > extend_flag->key = 'e';
> > extend_flag->description =
> > @@ -752,6 +771,23 @@
> > db_begin_transaction(driver);
> > + struct Map_info vector_mask;
> > + int naareas;
> > + int aarea;
> > + struct bound_box *mask_area_boxes;
> > + int invert_mask = 0;
> > + if (vector_mask_opt->answer) {
> > + if (Vect_open_old2(&vector_mask, vector_mask_opt->answer, "",
> vector_mask_field_opt->answer) < 2)
> > + G_fatal_error(_("Failed to open vector <%s>"),
> vector_mask_opt->answer);
> > + naareas = Vect_get_num_areas(&vector_mask);
> > + mask_area_boxes = G_malloc(naareas * sizeof(struct bound_box));
> > + for (aarea = 1; aarea <= naareas; aarea++) {
> > + Vect_get_area_box(&vector_mask, aarea,
> &mask_area_boxes[aarea - 1]);
> > + if (invert_mask_flag->answer)
> > + invert_mask = 1;
> > /* Import feature */
> > points_imported = 0;
> > cat = 1;
> > @@ -760,6 +796,7 @@
> > n_outside = 0;
> > n_filtered = 0;
> > n_class_filtered = 0;
> > + n_outside_mask = 0;
> > Points = Vect_new_line_struct();
> > Cats = Vect_new_cats_struct();
> > @@ -817,6 +854,19 @@
> > continue;
> > + skipme = TRUE;
> > + if (Vect_point_in_area(x, y, &vector_mask, aarea,
> &mask_area_boxes[aarea - 1])) {
> > + skipme = FALSE;
> > + break;
> > + if (invert_mask ^ skipme) {
> > + n_outside_mask++;
> > + continue;
> > if (return_filter != LAS_ALL) {
> > int return_no = LASPoint_GetReturnNumber(LAS_point);
> > int n_returns = LASPoint_GetNumberOfReturns(LAS_point);
> > @@ -992,6 +1042,11 @@
> > db_close_database_shutdown_driver(driver);
> > + Vect_close(&vector_mask);
> > + G_free(mask_area_boxes);
> > LASSRS_Destroy(LAS_srs);
> > LASHeader_Destroy(LAS_header);
> > LASReader_Destroy(LAS_reader);
> > @@ -1004,7 +1059,7 @@
> > /* can be easily determined only when iterated over all points */
> > if (!limit_n && !cat_max_reached && points_imported != n_features
> > - not_valid - n_outside - n_filtered - n_class_filtered
> > - - offset_n_counter - n_count_filtered)
> > + - n_outside_mask - offset_n_counter - n_count_filtered)
> > G_warning(_("The underlying libLAS library is at its limits."
> > " Previously reported counts might have been
> distorted."
> > " However, the import itself should be
> unaffected."));
> > @@ -1018,6 +1073,8 @@
> > G_message(_("%llu input points were not valid"), not_valid);
> > if (n_outside)
> > G_message(_("%llu input points were outside of the selected
> area"), n_outside);
> > + if (n_outside_mask)
> > + G_message(_("%llu input points were outside of the area
> specified by mask"), n_outside_mask);
> > if (n_filtered)
> > G_message(_("%llu input points were filtered out by return
> number"), n_filtered);
> > if (n_class_filtered)
> > @@ -1035,6 +1092,8 @@
> > G_message(_("%lu input points were not valid"), not_valid);
> > if (n_outside)
> > G_message(_("%lu input points were outside of the selected
> area"), n_outside);
> > + G_message(_("%lu input points were outside of the area
> > if (n_filtered)
> > G_message(_("%lu input points were filtered out by return
> > grass-commit mailing list
> > grass-commit at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-commit
> Martin Landa
> http://geo.fsv.cvut.cz/gwiki/Landa
> http://gismentors.cz/mentors/landa
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151112/16d4ced4/attachment-0001.html>
