[GRASS-dev] [GRASS GIS] #2798: v.centerline fails with real data
trac at osgeo.org
Mon Nov 16 05:23:51 PST 2015
Reporter: martinl | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.1
Component: Addons | Version: svn-trunk
Resolution: | Keywords: v.centerline
CPU: Unspecified | Platform: Unspecified
Comment (by mlennert):
Replying to [comment:5 martinl]:
> Replying to [comment:4 mlennert]:
> > v.centerline is meant for bundles of lines that have more of less the
same trajectory and for which you want to define one "mean" line. As shown
in the examples in the man page this could be two lines representing the
riverbanks, or more lines representing the variance of trajectories along
a more or less similar direction, such as lines of flight of airplanes
above a specific area.
> it seems to me that this also that case, there are two traffic lines for
each highway.
> > I don't really know what the "centerline" should be in your case ?
> A line between two traffic lines.
After importing and zooming I can see what you mean. In order to get the
centerlines of each of the highway pieces, you would have to iterate
through them and apply v.centerline to each of them as v.centerline in its
current state takes all lines in the map at once.
Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/2798#comment:6>
