[GRASS-dev] Different v.mkgrid table output depending on grid size
Maris Nartiss
maris.gis at gmail.com
Sat Nov 28 01:08:45 PST 2015
I would call it a (undocumented) feature not a bug as it dates back to
initial revision of v.mkgrid.
Unfortunately I could not find the initial commit with a rationale
behind magical number 27. Earliest change I found was from 2004, when
Radim just commits v.mkgrid with message "upgrade". It is possible
that this feature(?) dates back to original version "Written by GRASS,
Fall of 88, Michael H." thus its original meaning seems to be lost.
I would suggest to go to trac and open a bug (with a patch,
preferably). Question, of course, is - which behaviour is the correct
one (count from bottom, count from top).
https://trac.osgeo.org/grass/changeset/13320
Māris.
2015-11-28 0:14 GMT+02:00 Michel Wortmann <wortmann at pik-potsdam.de>:
> Hi Devs,
> I have been using the v.mkgrid command extensively recently and noticed that
> the tables of the output differ depending on the grid size. Apart from not
> having the columns rown and coln, larger grids’ row column counts from
> bottom to top rather than top to bottom as with smaller grids. I have dug in
> the code and found the appropriate lines in the main.c:
> 447 if (grid_info.num_rows < 27 && grid_info.num_cols <
> 27) {
> 448 sprintf(buf, "( %d, %d, %d, '%c', '%c' )",
> 449 attCount + 1, grid_info.num_rows - i,
> 450 j + 1, 'A' + grid_info.num_rows - i - 1,
> 'A' + j);
> 451 }
> 452 else {
> 453 sprintf(buf, "( %d, %d, %d )",
> 454 attCount + 1, i + 1, j + 1);
> Has this a good reason or is this a bug? I guess inconsistent output is
> undesirable here.
> Best,
> Michel
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
