[GRASS-dev] proposal for g.search module
Yann
ychemin at gmail.com
Sat Nov 28 06:52:28 PST 2015
+1 awesomeness
+1 for trunk
On 27/11/2015 17:12, Vaclav Petras wrote:
> On Fri, Nov 27, 2015 at 10:51 AM, Jachym Cepicky <jachym.cepicky at gmail.com>
> wrote:
>> Hi all,
>> I've tried to implement command line alternative to module search based on
>> keywords, which is available in the gui - it's called g.search
>> Any chance, you might find this useful ? Any comment to the source code
>> and outputs?
>> https://github.com/jachym/g.search
> I think it is awesome:
> $ g.extension extension=g.search url=https://github.com/jachym/g.search
> $ g.search MLC
> i.gensig
> Description: Generates statistics for i.maxlik from raster map.
> Keywords: imagery,classification,supervised classification,Maximum
> Likelihood Classification,MLC,signatures
> i.maxlik
> Description: Classifies the cell spectral reflectances in imagery data.
> Classification is based on the spectral signature information generated by
> either i.cluster, g.gui.iclass, or i.gensig.
> Keywords: imagery,classification,Maximum Likelihood Classification,MLC
> The code is minimalistic, so the duplication with GUI code is minimal or
> none.
> I suggest to put it to trunk, but to consider the name first. g.search
> sounds good but does it search modules or maps or both? Are the maps a
> possible extension of the current functionality?
> Vaclav
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
Yann Chemin
Address: 3 Toul Melin, 56400 Plumergat
Mobile: +33 (0)7 83 85 52 34
