[GRASS-dev] proposal for g.search module
Vaclav Petras
wenzeslaus at gmail.com
Mon Nov 30 13:33:29 PST 2015
On Mon, Nov 30, 2015 at 4:22 PM, Markus Neteler <neteler at osgeo.org> wrote:
> > Considering the fact that an important/main use case is interactive
> usage in
> > the command line, I now lean towards:
> > g.search.module aspect
> I would suggest to not use the singular "module" but plural "modules"
> which would better explain itself.
> We are searching in multiple modules, aren't we?
> So my suggestion:
> g.search.modules
Right! We are also getting multiple modules as a result. The GUI tab is
called Search modules, I've mentioned here myself but then forgot about it.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151130/924616e0/attachment.html>
