[GRASS-dev] installing v.kriging addon fails
Paulo van Breugel p.vanbreugel at gmail.com
Thu Oct 1 03:51:05 PDT 2015
On 29-09-15 15:46, Anna Petrášová wrote:
> On Tue, Sep 29, 2015 at 8:25 AM, Moritz Lennert
> <mlennert at club.worldonline.be <mailto:mlennert at club.worldonline.be>>
> wrote:
>     On 29/09/15 11:09, Paulo van Breugel wrote:
>         Installing v.kriging (on GRASS dev, Linux) addons fails with
>         the following:
>         GRASS 7.1.svn (latlon):~ > g.extension v.kriging
>         WARNING: Extension <v.kriging> already installed. Re-installing...
>         Fetching <v.kriging> from GRASS GIS Addons repository (be
>         patient)...
>         Compiling...
>         In file included from geostat.c:1:0:
>         local_proto.h:72:3: error: unknown type name ‘mat_struct’
>             mat_struct *trend;
>         local_proto.h:113:3: error: unknown type name ‘mat_struct’
>             mat_struct *gamma;    // experimental variogram matrix
>         local_proto.h:124:3: error: unknown type name ‘mat_struct’
>             mat_struct *A;           // plan matrix
>         local_proto.h:125:3: error: unknown type name ‘mat_struct’
>             mat_struct *T;           // coefficients of theoretical
>         variogram
>         local_proto.h:126:3: error: unknown type name ‘mat_struct’
>             mat_struct *GM;          // GM = theor_var(dist: input,
>         output points)
>         local_proto.h:218:1: error: unknown type name ‘mat_struct’
>           mat_struct *LSM(mat_struct *, mat_struct *);
>         local_proto.h:218:17: error: unknown type name ‘mat_struct’
>         local_proto.h:218:31: error: unknown type name ‘mat_struct’
>         local_proto.h:219:1: error: unknown type name ‘mat_struct’
>           mat_struct *nonlin_LMS(int , double *, double *);
>         local_proto.h:226:24: error: unknown type name ‘mat_struct’
>           double bivar_sill(int, mat_struct *);
>         local_proto.h:245:68: error: unknown type name ‘mat_struct’
>           void write2file_variogram_E(struct int_par *, struct
>         parameters *,
>         mat_struct *);
>         local_proto.h:250:1: error: unknown type name ‘mat_struct’
>           mat_struct *set_up_G(struct points *, struct parameters *,
>         struct
>         write *);
>         local_proto.h:251:1: error: unknown type name ‘mat_struct’
>           mat_struct *set_up_g0(struct int_par *, struct points *,
>         struct ilist
>         *, double *, struct parameters *);
>         local_proto.h:252:1: error: unknown type name ‘mat_struct’
>           mat_struct *submatrix(struct ilist *, mat_struct *, struct
>         write *);
>         local_proto.h:252:39: error: unknown type name ‘mat_struct’
>         write *);
>         local_proto.h:253:49: error: unknown type name ‘mat_struct’
>           double result(struct points *, struct ilist *, mat_struct *);
>         geostat.c: In function ‘E_variogram’:
>         geostat.c:101:5: error: unknown type name ‘mat_struct’
>               mat_struct *gamma_M;        // gamma matrix (hz, vert or
>         bivar)
>         geostat.c:102:5: error: unknown type name ‘mat_struct’
>               mat_struct *c_M;            // matrix of # of
>         dissimilarities
>         geostat.c:145:9: warning: assignment makes pointer from
>         integer without
>         a cast [enabled by default]
>               c_M = G_matrix_init(nrows, ncols, nrows);   // temporal
>         matrix of
>         counts
>         geostat.c:146:13: warning: assignment makes pointer from
>         integer without
>               gamma_M = G_matrix_init(nrows, ncols, nrows);      //
>         temporal
>         matrix (vector) of gammas
>         geostat.c:158:13: error: request for member ‘vals’ in
>         something not a
>         structure or union
>               c = &c_M->vals[0];
>         geostat.c:159:21: error: request for member ‘vals’ in
>         something not a
>         structure or union
>               gamma = &gamma_M->vals[0];
>         geostat.c:308:21: warning: assignment makes pointer from
>         integer without
>               var_pars->gamma = G_matrix_copy(gamma_M);
>         geostat.c: In function ‘ordinary_kriging’:
>         geostat.c:516:5: error: unknown type name ‘mat_struct’
>               mat_struct *GM;
>         geostat.c:517:5: error: unknown type name ‘mat_struct’
>               mat_struct *GM_sub;         // submatrix of selected points
>         geostat.c:518:5: error: unknown type name ‘mat_struct’
>               mat_struct *GM_Inv;         // inverted GM (GM_sub) matrix
>         geostat.c:519:5: error: unknown type name ‘mat_struct’
>               mat_struct *g0;             // diffences between known
>         and unknown
>         values = theor_var(dist)
>         geostat.c:520:5: error: unknown type name ‘mat_struct’
>               mat_struct *w0;             // weights of values located
>         on the
>         input points
>         geostat.c:545:17: warning: assignment makes pointer from
>         integer without
>               var_par->GM = G_matrix_copy(GM);    // copy matrix
>         because of
>         cross validation
>         geostat.c:589:28: warning: assignment makes pointer from
>         integer without
>                               GM_sub = submatrix(list, GM, report);
>         make submatrix for selected points
>         geostat.c:590:28: warning: assignment makes pointer from
>         integer without
>                               GM_Inv = G_matrix_inverse(GM_sub);  //
>         invert
>         submatrix
>         geostat.c:594:24: warning: assignment makes pointer from
>         integer without
>                               w0 = G_matrix_product(GM_Inv, g0);  //
>         Vector of
>         weights, condition SUM(w) = 1 in last row
>         make: *** [OBJ.x86_64-unknown-linux-gnu/geostat.o] Error 1
>         ERROR: Compilation failed, sorry. Please check above error
>         messages.
>     mat_struct is defined in include/la.h. I'm not 100% sure, but
>     IIUC, you might have to compile GRASS with blas/lapack support for
>     this to work.
> Yes, --with-blas and --with-lapack work for me.
I already had GRASS compiled with both blas and lapack, so that doesn't
seem to help in my case (just tried again, still no luck).
> Anna
>     Moritz
>     Moritz
>     _______________________________________________
>     grass-dev mailing list
>     grass-dev at lists.osgeo.org <mailto:grass-dev at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151001/7cceee0b/attachment-0001.html>
