[GRASS-dev] Write array to (point) attribute table
    Paulo van Breugel
    p.vanbreugel at gmail.com
    Thu Oct  1 08:34:26 PDT 2015
Hi Michel,
Thanks! I think I got the suggestions by Anna, Pietro and Moritz
working, but this certainly looks like an handy function to have at
hand. One possible disadvantage if using this in a script to be shared
with others is that it would add an dependency on pandas, wouldn't it?
Cheers,
Paulo
On 01-10-15 10:01, Michel Wortmann wrote:
> Hi Paulo,
> I had the same problem some time ago. I am using pandas for a lot of
> things and discovered the quickest way to append a column to a vector
> table is using pandas' .to_sql dataframe method. Here is my full
> function for it:
> import pandas as pa
> dataframe = pa.DataFrame( ... )
> def appendColumns(vecttbl,dataframe,join=None,layer=1):
>      '''Upload a DataFrame (Series should be first converted into a sql compliant datafram)
>      to a grass vector table. Join is a valid column in vecttbl or if None take categories.
>      Always joins on df.index, which is not uploaded.'''
>      # get sqlite.db info
>      db = grass.vector_db(vecttbl)[layer]
>      con = sqlite3.connect(db['database'])
>      # decide join indeces
>      itbl = {False:db['key'],True:join}[join!=None]
>      # make series to dataframe
>      dataframe.to_sql('pandas_temp',con,if_exists='replace',index_label='ix') # index label?
>      # join columns to vecttbl
>      grass.run_command('v.db.join',map=vecttbl,column=itbl,
>                         other_table='pandas_temp',other_column='ix',
>                         subset_columns=','.join(map(str,dataframe.columns)))
>      # remove temp table
>      cur = con.cursor()
>      cur.execute('DROP TABLE IF EXISTS pandas_temp')
>      con.commit(); con.close()
>      return
> The dataframe.to_sql line is essentially all you need, the rest of the
> function is just prepping.
> Hope it helps,
> Michel
> On 10/01/2015 12:05 AM, Paulo van Breugel wrote:
>> On 30-09-15 17:52, Paulo van Breugel wrote:
>>> On 30-09-15 17:47, Anna Petrášová wrote:
>>>> On Wed, Sep 30, 2015 at 11:20 AM, Paulo van Breugel
>>>> <p.vanbreugel at gmail.com> wrote:
>>>>     On 30-09-15 16:18, Anna Petrášová wrote:
>>>>>     On Wed, Sep 30, 2015 at 9:27 AM, Paulo van Breugel
>>>>>     <p.vanbreugel at gmail.com <mailto:p.vanbreugel at gmail.com>> wrote:
>>>>>         On Wed, Sep 30, 2015 at 11:53 AM, Pietro
>>>>>         <peter.zamb at gmail.com> wrote:
>>>>>             On Wed, Sep 30, 2015 at 9:51 AM, Paulo van Breugel
>>>>>             > On Wed, Sep 30, 2015 at 2:02 AM, Anna Petrášová
>>>>>             <kratochanna at gmail.com>
>>>>>             > wrote:
>>>>>             >> On Tue, Sep 29, 2015 at 6:09 PM, Paulo van Breugel
>>>>>             >>> This must be a very basic question, but I can't
>>>>>             find an easy/direct way
>>>>>             >>> to do this. In python, if I have an array with
>>>>>             values with a length equal to
>>>>>             >>> the number of rows in an attribute table of a
>>>>>             (point) vector layer, how can
>>>>>             >>> I write those values to a new column in that
>>>>>             attribute table. I can of
>>>>>             >>> course first create the column, but than how to
>>>>>             update that column with the
>>>>>             >>> values in the array?
>>>>>             >> it should be pretty easy to do with pygrass,
>>>>>             unfortunately there is no
>>>>>             >> example on assigning attributes in the official
>>>>>             documentation [1],  but it
>>>>>             >> should be pretty easy, something like that (not
>>>>>             tested):
>>>>>             >> with VectorTopo('myvector', mode='w') as vectormap:
>>>>>             >>     for feature in vectormap:
>>>>>             >>  feature.attrs['mycolumn'] = value
>>>>>             > Thanks, but that seems to write the vector back
>>>>>             without attribute table
>>>>>             You have to save the changes in the database out from
>>>>>             your cycle, with:
>>>>>             vectormap.table.conn.commit()
>>>>>         Thanks Pietro. I am, however, not sure I understand (I
>>>>>         tried to use it, but thanks to my limited experience in
>>>>>         Python / pygrass not much luck). Just to be more specific,
>>>>>         I am trying to create a script that divides points in
>>>>>         training and test groups, similar to v.kcv, but with
>>>>>         points clustered in space. E.g.,
>>>>>         # Create vector
>>>>>         grass.run_command("v.random", output="testB", npoints=10,
>>>>>         overwrite=True)
>>>>>         grass.run_command("v.db.addtable", map="testB", columns="X
>>>>>         DOUBLE PRECISION,Y DOUBLE PRECISION,GR INTEGER")
>>>>>         grass.run_command("v.to.db", map="test", option="coor",
>>>>>         columns="X,Y")
>>>>>         # Create groups
>>>>>         vectmap = 'test'
>>>>>         cvals = array(grass.vector_db_select(vectmap, layer =
>>>>>         int(1), columns = 'X,Y')['values'].values()).astype(np.float)
>>>>>         centroids,_ = kmeans(cvals,2)
>>>>>         idx,_ = vq(cvals,centroids)
>>>>>         # write results to tabel
>>>>>         Now I would like to write idx to the column 'GR' in the
>>>>>         attribute table of 'test'.
>>>>>         p.s. I am first creating the XY columns now, but is there
>>>>>         a function to get the coordinates (cvals) in pygrass directly?
>>>>>     I don't fully understand the example,
>>>>     Thanks for the quick response. I basically have a list with
>>>>     values (idx in the example above) which I like to add as a
>>>>     column to the attribute table of an existing vector (point
>>>>     layer). The length of idx is equal to the number of rows in the
>>>>     attribute table. The solution of Anna seems like an elegant
>>>>     solution (and easier and more flexible than other solutions I
>>>>     tried using e.g., sqlite3). However, as I wrote, I end up with
>>>>     a vector without attribute table. You wrote that I "have to
>>>>     save the changes in the database out from your cycle, with:
>>>>     vectormap.table.conn.commit()". I am, however, not sure what
>>>>     you mean with 'out from your cycle' or how to implement that.
>>>> probably after the for cycle ends you would call this
>>>> 'vectormap.table.conn.commit()', if it doesn't works, try to put it
>>>> in the cycle (I am not sure what is supposed to work).
>>> I did try both, with no luck so-far. I'll give it another try
>>> though, perhaps I did something else wrong.
>> Tried out again, but after running the code below, I end up with an
>> empty vector layer (no points and no attribute table). Same if I put
>> the vectormap.table.conn.commit() in the for cycle.
>> import grass.script as grass
>> from grass.pygrass.vector import VectorTopo
>> grass.run_command("v.random", output="testB", npoints=10, overwrite=True)
>> grass.run_command("v.db.addtable", map="testB", columns="GR INTEGER")
>> with VectorTopo('testB', mode='w') as vectormap:
>>          feature.attrs['GR'] = 9
>>>>>     but yes, you can get coordinates:
>>>>>       print feature.x
>>>>>           print feature.y
>>>>     Great, thanks. I did not find this in the manual. If it is not
>>>>     there, perhaps it would be something worth including? I would
>>>>     not mind providing a text, but I am not sure what would be the
>>>>     best way to do that.
>>>> Technically, it's in the manual:
>>>> https://grass.osgeo.org/grass70/manuals/libpython/pygrass_vector.html#geometry-classes
>>>> but we are lacking more examples of often used constructions. Some
>>>> other examples are available in the recent workshop we did:
>>>> https://github.com/wenzeslaus/python-grass-addon/blob/master/02_pygrass_library.ipynb
>>> Thanks, I will have a look at it.
>>>>>             Pietro
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151001/75022605/attachment-0001.html>
