[GRASS-dev] Write array to (point) attribute table
Michel Wortmann
wortmann at pik-potsdam.de
Thu Oct 1 01:01:20 PDT 2015
Hi Paulo,
I had the same problem some time ago. I am using pandas for a lot of
things and discovered the quickest way to append a column to a vector
table is using pandas' .to_sql dataframe method. Here is my full
function for it:
import pandas as pa
dataframe = pa.DataFrame( ... )
def appendColumns(vecttbl,dataframe,join=None,layer=1):
'''Upload a DataFrame (Series should be first converted into a sql compliant datafram)
to a grass vector table. Join is a valid column in vecttbl or if None take categories.
Always joins on df.index, which is not uploaded.'''
# get sqlite.db info
db = grass.vector_db(vecttbl)[layer]
con = sqlite3.connect(db['database'])
# decide join indeces
itbl = {False:db['key'],True:join}[join!=None]
# make series to dataframe
dataframe.to_sql('pandas_temp',con,if_exists='replace',index_label='ix') # index label?
# join columns to vecttbl
grass.run_command('v.db.join',map=vecttbl,column=itbl,
other_table='pandas_temp',other_column='ix',
subset_columns=','.join(map(str,dataframe.columns)))
# remove temp table
cur = con.cursor()
cur.execute('DROP TABLE IF EXISTS pandas_temp')
con.commit(); con.close()
return
The dataframe.to_sql line is essentially all you need, the rest of the
function is just prepping.
Hope it helps,
Michel
On 10/01/2015 12:05 AM, Paulo van Breugel wrote:
> On 30-09-15 17:52, Paulo van Breugel wrote:
>> On 30-09-15 17:47, Anna Petrášová wrote:
>>> On Wed, Sep 30, 2015 at 11:20 AM, Paulo van Breugel
>>> <p.vanbreugel at gmail.com> wrote:
>>> On 30-09-15 16:18, Anna Petrášová wrote:
>>>> On Wed, Sep 30, 2015 at 9:27 AM, Paulo van Breugel
>>>> <p.vanbreugel at gmail.com <mailto:p.vanbreugel at gmail.com>> wrote:
>>>> On Wed, Sep 30, 2015 at 11:53 AM, Pietro
>>>> <peter.zamb at gmail.com> wrote:
>>>> On Wed, Sep 30, 2015 at 9:51 AM, Paulo van Breugel
>>>> > On Wed, Sep 30, 2015 at 2:02 AM, Anna Petrášová
>>>> <kratochanna at gmail.com>
>>>> > wrote:
>>>> >> On Tue, Sep 29, 2015 at 6:09 PM, Paulo van Breugel
>>>> >>> This must be a very basic question, but I can't
>>>> find an easy/direct way
>>>> >>> to do this. In python, if I have an array with
>>>> values with a length equal to
>>>> >>> the number of rows in an attribute table of a
>>>> (point) vector layer, how can
>>>> >>> I write those values to a new column in that
>>>> attribute table. I can of
>>>> >>> course first create the column, but than how to
>>>> update that column with the
>>>> >>> values in the array?
>>>> >> it should be pretty easy to do with pygrass,
>>>> unfortunately there is no
>>>> >> example on assigning attributes in the official
>>>> documentation [1], but it
>>>> >> should be pretty easy, something like that (not tested):
>>>> >> with VectorTopo('myvector', mode='w') as vectormap:
>>>> >> for feature in vectormap:
>>>> >> feature.attrs['mycolumn'] = value
>>>> > Thanks, but that seems to write the vector back
>>>> without attribute table
>>>> You have to save the changes in the database out from
>>>> your cycle, with:
>>>> vectormap.table.conn.commit()
>>>> Thanks Pietro. I am, however, not sure I understand (I
>>>> tried to use it, but thanks to my limited experience in
>>>> Python / pygrass not much luck). Just to be more specific,
>>>> I am trying to create a script that divides points in
>>>> training and test groups, similar to v.kcv, but with points
>>>> clustered in space. E.g.,
>>>> # Create vector
>>>> grass.run_command("v.random", output="testB", npoints=10,
>>>> overwrite=True)
>>>> grass.run_command("v.db.addtable", map="testB", columns="X
>>>> DOUBLE PRECISION,Y DOUBLE PRECISION,GR INTEGER")
>>>> grass.run_command("v.to.db", map="test", option="coor",
>>>> columns="X,Y")
>>>> # Create groups
>>>> vectmap = 'test'
>>>> cvals = array(grass.vector_db_select(vectmap, layer =
>>>> int(1), columns = 'X,Y')['values'].values()).astype(np.float)
>>>> centroids,_ = kmeans(cvals,2)
>>>> idx,_ = vq(cvals,centroids)
>>>> # write results to tabel
>>>> Now I would like to write idx to the column 'GR' in the
>>>> attribute table of 'test'.
>>>> p.s. I am first creating the XY columns now, but is there a
>>>> function to get the coordinates (cvals) in pygrass directly?
>>>> I don't fully understand the example,
>>> Thanks for the quick response. I basically have a list with
>>> values (idx in the example above) which I like to add as a
>>> column to the attribute table of an existing vector (point
>>> layer). The length of idx is equal to the number of rows in the
>>> attribute table. The solution of Anna seems like an elegant
>>> solution (and easier and more flexible than other solutions I
>>> tried using e.g., sqlite3). However, as I wrote, I end up with a
>>> vector without attribute table. You wrote that I "have to save
>>> the changes in the database out from your cycle, with:
>>> vectormap.table.conn.commit()". I am, however, not sure what you
>>> mean with 'out from your cycle' or how to implement that.
>>> probably after the for cycle ends you would call this
>>> 'vectormap.table.conn.commit()', if it doesn't works, try to put it
>>> in the cycle (I am not sure what is supposed to work).
>> I did try both, with no luck so-far. I'll give it another try though,
>> perhaps I did something else wrong.
> Tried out again, but after running the code below, I end up with an
> empty vector layer (no points and no attribute table). Same if I put
> the vectormap.table.conn.commit() in the for cycle.
> import grass.script as grass
> from grass.pygrass.vector import VectorTopo
> grass.run_command("v.random", output="testB", npoints=10, overwrite=True)
> grass.run_command("v.db.addtable", map="testB", columns="GR INTEGER")
> with VectorTopo('testB', mode='w') as vectormap:
> feature.attrs['GR'] = 9
>>>> but yes, you can get coordinates:
>>>> print feature.x
>>>> print feature.y
>>> Great, thanks. I did not find this in the manual. If it is not
>>> there, perhaps it would be something worth including? I would
>>> not mind providing a text, but I am not sure what would be the
>>> best way to do that.
>>> Technically, it's in the manual:
>>> https://grass.osgeo.org/grass70/manuals/libpython/pygrass_vector.html#geometry-classes
>>> but we are lacking more examples of often used constructions. Some
>>> other examples are available in the recent workshop we did:
>>> https://github.com/wenzeslaus/python-grass-addon/blob/master/02_pygrass_library.ipynb
>> Thanks, I will have a look at it.
>>>> Pietro
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151001/61db9c62/attachment-0001.html>
