[GRASS-dev] Write array to (point) attribute table
Paulo van Breugel p.vanbreugel at gmail.com
Fri Oct 2 00:03:49 PDT 2015
On 01-10-15 17:49, Vaclav Petras wrote:
> On Thu, Oct 1, 2015 at 11:28 AM, Paulo van Breugel
> <p.vanbreugel at gmail.com <mailto:p.vanbreugel at gmail.com>> wrote:
>     with VectorTopo('testB', mode='rw') as vectormap:
> At the and it makes sense. 'w' removes the vectors and starts over.
> 'rw' keep the file but ones it for writing. Perhaps 'a' would make
> better sense in this case. What the documentation says?
On https://grass.osgeo.org/grass70/manuals/libpython/pygrass_vector.html
it is mentioned that:
"/The open() method supports a number of option arguments (see the Info
documentation for a complete list). In particular, the mode argument can
take a a value of r for reading, w for writing, or rw for
reading/writing." [...] /"/If a vector map is opened with the mode w or
rw, then the user can write new features to the dataset/".
I think this description is somewhat ambiguous. Especially the mode='w'
is unclear to me; I could clearly not write new features to an
(existing) vector layer. It might be nice to have a short one-line
explanation of each of these options, explaining the difference.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151002/32ee7263/attachment.html>
