[GRASS-dev] no addons metadata
Vaclav Petras
wenzeslaus at gmail.com
Thu Oct 1 08:51:59 PDT 2015
On Thu, Oct 1, 2015 at 10:42 AM, Paulo van Breugel <p.vanbreugel at gmail.com>
wrote:
> The same problem as reported earlier is back it seems, no addons metadata
> available. This was a problem for 7.1 I think?
> WARNING: Unable to parse
> 'http://grass.osgeo.org/addons/grass7/modules.xml': no element
> found: line 105, column 0
> WARNING: No addons metadata available. Addons metadata file not updated.
It seems like problem with generating the file on the server side. If you
visit the URL, you get:
XML Parsing Error: no element found
Location: https://grass.osgeo.org/addons/grass7/modules.xml
Line Number 105, Column 1:
> Installation of <v.kriging> successfully finished
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151001/9ac3566a/attachment.html>
