[GRASS-dev] no addons metadata
Martin Landa
landa.martin at gmail.com
Thu Oct 1 08:55:34 PDT 2015
2015-10-01 17:51 GMT+02:00 Vaclav Petras <wenzeslaus at gmail.com>:
> It seems like problem with generating the file on the server side. If you
> visit the URL, you get:
> XML Parsing Error: no element found
> Location: https://grass.osgeo.org/addons/grass7/modules.xml
> Line Number 105, Column 1:
I checked modules.xml on build server, and it's OK. Strangely
modules.xml (which is copied from build server to osgeo server) is
broken. I fix it launching copying script manually.
@Markus: just to be sure aren't you not running any cronjob related to
addons on osgeo server?
Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
