[GRASS-dev] r.watershed at poles
Sören Gebbert soerengebbert at googlemail.com
Fri Oct 2 00:04:39 PDT 2015
Hi Andy,
running r.watershed for the whole globe is IMHO not necessary. Just
run r.watershed for each continent (except Europe/Asia) and isles
(greenland, UK, ...). Everything that is parted by an ocean or a
channel can be processed independently.
Best regards
Soeren
2015-10-02 0:27 GMT+02:00 Andy Wickert <andrewwickert at gmail.com>:
> On Thu, Oct 1, 2015 at 3:52 PM, Markus Neteler <neteler at osgeo.org> wrote:
>> On Thu, Oct 1, 2015 at 7:10 AM, Andy Wickert <andrewwickert at gmail.com>
>> wrote:
>> > Dear GRASS developers,
>> > Would you know of an easy way to make r.watershed work in
>> > latitude/longitude
>> > over the pole of a planet (in my case, over Antarctica) by specifying
>> > that
>> > the polar boundary in lat/lon is not a sink?
>> Wouldn't be a stereographic projection more appropriate?
>> https://grass.osgeo.org/uploads/images/Gallery/raster/polar_stereographic.png
>> Best
>> Markus
> Thanks for the suggestion. However, my goal is to run r.watershed across the
> whole globe, so a stereographic projection would an ad-hoc solution.
> (I have also had problems in the past projecting between polar stereographic
> and lat/lon, but this is a secondary issue.)
> Andy
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
