[GRASS-dev] compile errors when using stripped-down config
Soren Harward stharward at gmail.com
Fri Oct 2 07:31:29 PDT 2015
I'm working on packaging 7.0.1 (well, writing a new ebuild) for Gentoo
Linux. When testing a totally stripped down configuration (ie, everything
disabled that could be), I ran into a couple of compile errors.  Here are
things that need to be fixed:
#1: ./lib/raster/open.c needs to include <errno.h> explicitly. Otherwise
errno is undefined at line 595.
#2: ./general/g.proj/main.c declares the variable "inepsg" only if HAVE_OGR
is defined, but then uses this symbol outside "#ifdef HAVE_OGR" in lines
302 and 322. I'm not exactly sure how to fix this.
Soren Harward
Soren Harward
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151002/ea87818f/attachment.html>
