[GRASS-dev] compile errors when using stripped-down config
Martin Landa landa.martin at gmail.com
Fri Oct 2 07:46:00 PDT 2015
Hi Soren,
2015-10-02 16:31 GMT+02:00 Soren Harward <stharward at gmail.com>:
> #1: ./lib/raster/open.c needs to include <errno.h> explicitly. Otherwise
> errno is undefined at line 595.
> #2: ./general/g.proj/main.c declares the variable "inepsg" only if HAVE_OGR
> is defined, but then uses this symbol outside "#ifdef HAVE_OGR" in lines 302
> and 322. I'm not exactly sure how to fix this.
first of all, thanks for reporting the issue. The both issues should
be fixed in r66397 in trunk. Please could you test it?
Thanks! Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
