[GRASS-dev] compile errors when using stripped-down config
Maris Nartiss
maris.gis at gmail.com
Sat Oct 3 00:46:34 PDT 2015
Hello,
some of GRASS compilation "options" are not optional at all -
resulting outcome even if will work, will be useless for endusers.
Don't try to push everything into use flags.
I haven't been trying to install GRASS from ebuilds since 6.0.0 days,
still I could test on ~AMD64. Feel free to contact me offlist.
Māris.
2015-10-02 17:31 GMT+03:00 Soren Harward <stharward at gmail.com>:
> I'm working on packaging 7.0.1 (well, writing a new ebuild) for Gentoo
> Linux. When testing a totally stripped down configuration (ie, everything
> disabled that could be), I ran into a couple of compile errors. Here are
> things that need to be fixed:
> #1: ./lib/raster/open.c needs to include <errno.h> explicitly. Otherwise
> errno is undefined at line 595.
> #2: ./general/g.proj/main.c declares the variable "inepsg" only if HAVE_OGR
> is defined, but then uses this symbol outside "#ifdef HAVE_OGR" in lines 302
> and 322. I'm not exactly sure how to fix this.
> Soren Harward
> Soren Harward
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
