[GRASS-dev] compile errors when using stripped-down config
Martin Landa landa.martin at gmail.com
Fri Oct 2 10:04:45 PDT 2015
2015-10-02 16:54 GMT+02:00 Soren Harward <stharward at gmail.com>:
> On Fri, Oct 2, 2015 at 10:46 AM, Martin Landa <landa.martin at gmail.com> wrote:
>> first of all, thanks for reporting the issue. The both issues should
>> be fixed in r66397 in trunk. Please could you test it?
> That compiles fine. Thanks!
backported to grass70 release branch as r663978. Ma
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
