[GRASS-dev] I've tripled GRASS's I/O speed
Vaclav Petras
wenzeslaus at gmail.com
Wed Oct 7 19:58:11 PDT 2015
On Wed, Oct 7, 2015 at 8:45 PM, Seth Price <seth at planet.com> wrote:
> I figured it out. I had to `make clean && make && sudo make install` to
> get unit tests working as expected.
Makes sense. I should have suggested that. I was doing make distclean
automatically out of a habit since the change is in the library.
> I just uploaded a new version of the code that shouldn't fail any
> additional unit tests, and I've added unit tests to r.compress that test
> reading/writing the different compression schemes.
Glad to hear that. Replied to the ticket (copy goes to grass-dev):
https://trac.osgeo.org/grass/ticket/2750#comment:6
~Seth
> On Tue, Oct 6, 2015 at 5:54 AM, Vaclav Petras <wenzeslaus at gmail.com>
> wrote:
>> On Tue, Oct 6, 2015 at 1:42 AM, Seth Price <seth at planet.com> wrote:
>>> Sorry for derailing my own thread, but here we go again...
>>> I'm having a hard time reproducing anything with the unit tests. There
>>> seems to be some state that exists between unit test runs.
>> What are the actual errors in the HTML report?
>>> I ran it with my updated code, and I got 30% failed. Then I ran the new
>>> code with the tests, and I'm getting 30% failed. So I deleted the basic
>>> location directory and re-decompressed it. Now I'm getting 31% failed in
>>> both directories.
>>> Using these commands, as shown above, resulted in 21% failed. I'm
>>> running `make && sudo make install` when I switch directories. Then I
>>> delete & refresh the location files. Then I run the unit tests as `python
>>> -m grass.gunittest.main --location nc_basic_spm_grass7 --location-type nc`.
>>> What's wrong with my test procedure?
>> Sorry, I don't understand what is the difference between new code and
>> updated code. When you get 30, 31 21%? What are the actual commands you are
>> running?
>> If you are concerned about reproducibility, use VM or Docker, e.g. with
>> Ubuntu [1]. In this way, we can see if it is a local or Mac issue or not.
>> [1] https://github.com/wenzeslaus/grass-gis-docker
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151007/0a006ce1/attachment.html>
