[GRASS-dev] Planning of 7.0.2 release
Markus Neteler
neteler at osgeo.org
Sat Oct 3 02:03:16 PDT 2015
On Sat, Oct 3, 2015 at 11:01 AM, Martin Landa <landa.martin at gmail.com> wrote:
> Hi,
> 2015-10-03 10:45 GMT+02:00 Markus Neteler <neteler at osgeo.org>:
>> - r64404 - libpython: move cmd list <-> tuple from wxGUI: martinl
>> Date: Feb 2, 2015
>> - r64406 - wxGUI: replace utils cmd list <-> tuple by
>> grass.script.gtask functions
>> - r65634 (wxGUI: move import/export dialogs from gui_core to modules -
>> wxGUI source code compatibility) - No idea?
> not sure, these changes don't fix anything in wxGUI. My suggestion is
> to skip backport and focus on trunk development which should lead to
> 7.1 release (spring 2016?). The code inconsistency between branches
> can complicate backporting, but I would not expect so many backports.
> Any opinion?
>> - r65774, r66129 - remove 'display map' tool - ?? not backported to
>> far. Out of scope?
> I would suggest to keep 'display map' tool in 7.0. It's not bugfix.
> Let's try to backport only bugfixes and minor issues (keywords, ...).
ok - just update the trac page then and drop it or move to a later
release number.
I'm not able to judge the wx* changes at all.
Markus
