[GRASS-dev] [GRASS-SVN] r66413 - grass-addons/grass7/vector/v.kriging
Vaclav Petras
wenzeslaus at gmail.com
Mon Oct 5 07:49:11 PDT 2015
On Mon, Oct 5, 2015 at 3:44 AM, Martin Landa <landa.martin at gmail.com> wrote:
> Hi,
> 2015-10-05 9:41 GMT+02:00 Martin Landa <landa.martin at gmail.com>:
> > compilation was simply failing on build server (Debian stable):
It is working on Ubuntu and probably Fedora as well. Perhaps it is a local
issue.
> >> In file included from main.c:47:0:
> >> global.h:28:29: error: unknown type name ‘vec_struct’
> >> global.h:28:43: error: unknown type name ‘vec_struct’
> >> global.h:31:8: error: unknown type name ‘mat_struct’
> even GRASS is compiled with lapack and blas support. I checked config.h
again:
> /* define if LAPACK exists */
> #define HAVE_LIBLAPACK 1
> /* define if BLAS exists */
> #define HAVE_LIBBLAS 1
Then la.h should be included in gmath.h. Including it in modules in a
workaround, not the solution. There are three possible solutions:
1) remove la.h from gmath.h and declare that modules must include it (I
don't see a reason for this)
2) change la.h include in gmath.h to something else; perhaps #if
defined(...) && defined(...) is wrong (but I don't think so, seems to fit
with the standard)
3) find out why it is different on that server and think about the proper
fix afterwards (ideal)
I can't test it since I can't reproduce it.
Sorry for being -pedantic but I don't think we should leave the code messy.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151005/86e582b7/attachment.html>
