[GRASS-dev] I've tripled GRASS's I/O speed
Seth Price seth at planet.com
Mon Oct 5 14:07:21 PDT 2015
Thanks, I think I'm still getting the same issue. Here is me trying to run
tests with both "nc_basic_spm_grass7" and "ncarolina_smp_base0.3.2":
seths-mbp:grass-7.1.svn_src_snapshot_2015_09_19 sprice$ grass71 --text
../nc_basic_spm_grass7/PERMANENT/
Cleaning up temporary files...
GRASS 7.1.svn
(nc_basic_spm_grass7):/usr/local/grass/grass-7.1.svn_src_snapshot_2015_09_19
> python -m grass.gunittest.main --location
/usr/local/grass/nc_basic_spm_grass7/ --location-type nc
test_g_list from ./general/g.list failed (1 test failed)
test_g_remove from ./general/g.remove failed (2 tests failed)
test_overwrite from ./general/g.rename failed (3 tests failed)
toolboxes from ./gui/wxpython/core failed
test_vto3d from ./vector/v.to.3d failed (1 test failed)
test_vwhat_layers from ./vector/v.what failed (1 test failed)
test_vwhat_ncspm from ./vector/v.what failed (4 tests failed)
Executed 127 test files in 0:00:50.862606.
>From them 12 files (9%) were successful and 115 files (91%) failed.
GRASS 7.1.svn
> exit
../ncarolina_smp_base0.3.2/PERMANENT/
GRASS 7.1.svn
(ncarolina_smp_base0.3.2):/usr/local/grass/grass-7.1.svn_src_snapshot_2015_09_19
/usr/local/grass/ncarolina_smp_base0.3.2/ --location-type nc
test_v_net from ./vector/v.net failed (8 tests failed)
Executed 127 test files in 0:00:46.315482.
GRASS 7.1.svn
On Mon, Oct 5, 2015 at 1:18 PM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> On Mon, Oct 5, 2015 at 3:21 PM, Seth Price <seth at planet.com> wrote:
>> Hi, I've spent the last two or three hours trying to get GRASS' unit
>> tests running. With a fresh source tree, the best I can get is ~9% of the
>> tests passing:
> Oh, sorry about that, you need to use basic instead of full NC location.
> The datasets are unfortunately incompatible and the whole thing is
> undocumented because we never made the switch official.
> https://grass.osgeo.org/download/sample-data/
> But since NC basic will be replaced by standardized sample dataset (which
> is partially reason for the confusing situation), use this new dataset
> instead.
> https://trac.osgeo.org/grass/wiki/SampleDataset (goes here:
> http://www4.ncsu.edu/~hmitaso/grasswork/grassbookdat4ed/)
> Have you noticed that you can view the errors in an HTML report?
> "grass.gunittest.main writes a text summary to standard output and it
> creates an HTML report from all tests in all testsuite directories inside
> the directory tree. The report is placed in testreport by default. Open
> file testreport/index.html in you web browser to inspect it."
> https://grass.osgeo.org/grass71/manuals/libpython/gunittest_running_tests.html#running-tests-and-creating-report
>> ../nc_spm_08_grass7/PERMANENT/
>> GRASS 7.1.svn
>> (nc_spm_08_grass7):/usr/local/grass/grass-7.1.svn_src_snapshot_2015_09_19 >
>> /usr/local/grass/nc_spm_08_grass7/ --location-type nc
>> Executed 127 test files in 0:00:55.959398.
>> GRASS 7.1.svn
>> I'd really like to work on these unit tests. Any ideas as to where I'm
>> going wrong? I feel like I've exhausted the various knowledge bases
>> available online.
>> Thanks,
>> Seth
>> On Fri, Oct 2, 2015 at 11:25 AM, Vaclav Petras <wenzeslaus at gmail.com>
>> wrote:
>>> On Fri, Oct 2, 2015 at 12:49 PM, Seth Price <seth at planet.com> wrote:
>>>> ..by adding the option of a few different compression schemes,
>>>> including LZ4. I've had the ticket open for a week now with no responses.
>>>> I'd love to get it incorporated into trunk. For more info, see here:
>>>> https://trac.osgeo.org/grass/ticket/2750
>>> Hi,
>>> thanks for the reminder. This looks really good. Can you provide a test
>>> which would do a trivial operation (like the benchmark in the ticket)
>>> ideally using Python and gunittest [1]? Please, let me know if you don't
>>> know where to start.
>>> Vaclav
>>> [1]
>>> https://grass.osgeo.org/grass71/manuals/libpython/gunittest_testing.html
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151005/7c6e5d79/attachment-0001.html>
