[GRASS-dev] I've tripled GRASS's I/O speed
Seth Price
seth at planet.com
Mon Oct 5 15:23:15 PDT 2015
Ah, I see now. I have failed tests at 24% & 21% on a recent snapshot now:
GRASS 7.1.svn
(ncarolina_smp_base0.3.2):/usr/local/grass/grass-7.1.svn_src_snapshot_2015_09_19
> python -m grass.gunittest.main --location ncarolina_smp_base0.3.2
--location-type nc
test_assertions_vect from ./lib/python/gunittest failed (1 test failed)
test_doctests from ./lib/python/pygrass failed (3 tests failed)
test_v_net from ./vector/v.net failed (4 tests failed)
test_vwhat_ncspm from ./vector/v.what failed (4 tests failed)
Executed 127 test files in 0:24:05.986559.
>From them 96 files (76%) were successful and 31 files (24%) failed.
GRASS 7.1.svn
or
GRASS 7.1.svn
(nc_basic_spm_grass7):/usr/local/grass/grass-7.1.svn_src_snapshot_2015_09_19
> python -m grass.gunittest.main --location nc_basic_spm_grass7
--location-type nc
test_raster3d_algebra from ./temporal/t.rast3d.algebra failed (6 tests
failed)
test_vector_algebra from ./temporal/t.vect.algebra failed (14 tests failed)
Executed 127 test files in 0:24:47.877746.
>From them 100 files (79%) were successful and 27 files (21%) failed.
GRASS 7.1.svn
Is this expected?
On Mon, Oct 5, 2015 at 2:13 PM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> On Mon, Oct 5, 2015 at 5:07 PM, Seth Price <seth at planet.com> wrote:
> > --location /usr/local/grass/nc_basic_spm_grass7/
> python -m grass.gunittest.main --location locname --location-type nc
> where locname is a name of location in current GRASS GIS data(base)
> directory (GISDBASE) and nc is a location specified by individual test
> files (the later is not yet fully implemented, so just put there nc every
> time).
> https://grass.osgeo.org/grass71/manuals/libpython/gunittest_running_tests.html#running-tests-and-creating-report
> or:
> grass71 --exec python -m grass.gunittest.main --help
> --location LOCATION Name of location where to perform test
> I hope this helps.
> Have you found the HTMl output?
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151005/1b823cf5/attachment.html>
