[GRASS-dev] v.rast.stats disables MASK
Moritz Lennert
mlennert at club.worldonline.be
Tue Oct 6 08:32:23 PDT 2015
On 06/10/15 16:11, Martin Landa wrote:
> Hi all,
> v.rast.stats tries to disable MASK before doing statistics, what is a
> reason for that? BTW, in r66421 I fixed issue when MASK is not located
> in the current mapset (and cannot be disabled).
Just intrigued by this: I though the mask is mapset based, so how you
can you have an active mask in a mapset that is not defined within that
mapset ?
Moritz
