[GRASS-dev] v.rast.stats disables MASK
Martin Landa landa.martin at gmail.com
Tue Oct 6 08:46:18 PDT 2015
2015-10-06 17:32 GMT+02:00 Moritz Lennert <mlennert at club.worldonline.be>:
> Just intrigued by this: I though the mask is mapset based, so how you can
> you have an active mask in a mapset that is not defined within that mapset ?
yes, mask is mapset based. The problem is that `v.rast.stats` checks
first MASK raster map in the search path (not only in the current
mapset). Ma
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
