[GRASS-dev] v.rast.stats disables MASK
Moritz Lennert
mlennert at club.worldonline.be
Tue Oct 6 09:13:53 PDT 2015
On 06/10/15 17:46, Martin Landa wrote:
> 2015-10-06 17:32 GMT+02:00 Moritz Lennert <mlennert at club.worldonline.be>:
>> Just intrigued by this: I though the mask is mapset based, so how you can
>> you have an active mask in a mapset that is not defined within that mapset ?
> yes, mask is mapset based. The problem is that `v.rast.stats` checks
> first MASK raster map in the search path (not only in the current
> mapset). Ma
But this was a bug that you fixed in r66421, or ?
Moritz
