[GRASS-dev] [GRASS-SVN] r66413 - grass-addons/grass7/vector/v.kriging
Tue Oct 6 09:26:26 PDT 2015
Markus Neteler wrote:
> >> Sorry for being -pedantic but I don't think we should leave the code
> >> messy.
> > +1
> Then it needs to be removed everywhere here:
> cd grass-addons
> find . -type f | grep -v pristin | xargs grep 'la.h>'
> ./grass6/imagery/i.spec.unmix/global.h:#include <grass/la.h>
> ./grass6/imagery/i.spec.unmix/la_extra.c:#include <grass/la.h>
> ./grass6/imagery/i.spec.grass63/include/gmath.h:#include <grass/la.h>
> ./grass6/imagery/i.spec.grass63/lib/gmath/la.c:#include <grass/la.h>
> ./grass7/imagery/i.spec.unmix/global.h:#include <grass/la.h>
> ./grass7/vector/v.kriging/local_proto.h:#include <grass/la.h>
Sorry for joining in late, but from my understanding of the code, it
seems that the inclusion of <grass/la.h> should be in the modules, not
in <grass/gmath.h>.
<grass/gmath.h> defines a number of macros plus the G_math_spvector
type. It then includes <grass/defs/gmath.h> which contains a number of
function declarations, some of which use G_math_spvector in their
return or parameter types.
<grass/gmath.h> also includes <grass/la.h>, but doesn't depend upon
anything defined in that header. If the include of <grass/la.h> is
removed, compiling a source file containing only
	#include <grass/gmath.h>
succeeds. Consequently, there is no need for <grass/gmath.h> to
include <grass/la.h>.
Having one header for "base" functionality which is always available
and another for additional functionality which is only available when
GRASS was built with BLAS/LAPACK support seems cleaner than having a
single header expose both, particularly when the two have already been
separated.
Additionally, requiring individual modules to include <grass/la.h>
explicitly would make it clear when code depends upon BLAS/LAPACK.
