[GRASS-dev] [GRASS-SVN] r66413 - grass-addons/grass7/vector/v.kriging
Vaclav Petras
wenzeslaus at gmail.com
Tue Oct 6 10:43:21 PDT 2015
On Tue, Oct 6, 2015 at 12:26 PM, Glynn Clements <glynn at gclements.plus.com>
wrote:
> Markus Neteler wrote:
> > >> Sorry for being -pedantic but I don't think we should leave the code
> > >> messy.
> > > +1
> > Then it needs to be removed everywhere here:
> > cd grass-addons
> > find . -type f | grep -v pristin | xargs grep 'la.h>'
> > ./grass6/imagery/i.spec.unmix/global.h:#include <grass/la.h>
> > ./grass6/imagery/i.spec.unmix/la_extra.c:#include <grass/la.h>
> > ./grass6/imagery/i.spec.grass63/include/gmath.h:#include <grass/la.h>
> > ./grass6/imagery/i.spec.grass63/lib/gmath/la.c:#include <grass/la.h>
> > ./grass7/imagery/i.spec.unmix/global.h:#include <grass/la.h>
> > ./grass7/vector/v.kriging/local_proto.h:#include <grass/la.h>
> Sorry for joining in late, but from my understanding of the code, it
> seems that the inclusion of <grass/la.h> should be in the modules, not
> in <grass/gmath.h>.
> <grass/gmath.h> defines a number of macros plus the G_math_spvector
> type. It then includes <grass/defs/gmath.h> which contains a number of
> function declarations, some of which use G_math_spvector in their
> return or parameter types.
> <grass/gmath.h> also includes <grass/la.h>, but doesn't depend upon
> anything defined in that header. If the include of <grass/la.h> is
> removed, compiling a source file containing only
> #include <grass/gmath.h>
> succeeds. Consequently, there is no need for <grass/gmath.h> to
> include <grass/la.h>.
> Having one header for "base" functionality which is always available
> and another for additional functionality which is only available when
> GRASS was built with BLAS/LAPACK support seems cleaner than having a
> single header expose both, particularly when the two have already been
> separated.
> Additionally, requiring individual modules to include <grass/la.h>
> explicitly would make it clear when code depends upon BLAS/LAPACK.
I agree.
I was not able to determine from svn why gmath.h contains la.h.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151006/5a07cb5c/attachment-0001.html>
