[GRASS-dev] wx.metadata ready for testing
Paulo van Breugel p.vanbreugel at gmail.com
Wed Oct 7 01:14:25 PDT 2015
On 06-10-15 11:40, Martin Landa wrote:
> Hi,
> 2015-10-05 10:39 GMT+02:00 Matej Krejci <matejkrejci at gmail.com>:
>>   I just checked .grass7/addons/etc/wx.metadata and installation deployed
>> only /mdlib dir but no /configure and /profiles dirs. It is the same issue
>> like r.green[1]. Correctly placed directories should looks like:
> should be fixed in r66417. Testing welcome. Martin
Hi, just tried to install wx.metadata, using g.extension and by
compiling directly. As far as I know all dependencies are installed. The
full output when compiling from source:
make -C mdlib || echo /home/paulo/Software/spatial/grass-addons/gui/wxpython/wx.metadata/mdlib >> /usr/local/grass7/grass-7.1.svn/error.log
make[1]: Entering directory `/home/paulo/Software/spatial/grass-addons/gui/wxpython/wx.metadata/mdlib'
make[1]: Nothing to be done for `first'.
make[1]: Leaving directory `/home/paulo/Software/spatial/grass-addons/gui/wxpython/wx.metadata/mdlib'
make -C profiles || echo /home/paulo/Software/spatial/grass-addons/gui/wxpython/wx.metadata/profiles >> /usr/local/grass7/grass-7.1.svn/error.log
make[1]: Entering directory `/home/paulo/Software/spatial/grass-addons/gui/wxpython/wx.metadata/profiles'
make[1]: Leaving directory `/home/paulo/Software/spatial/grass-addons/gui/wxpython/wx.metadata/profiles'
make -C config || echo /home/paulo/Software/spatial/grass-addons/gui/wxpython/wx.metadata/config >> /usr/local/grass7/grass-7.1.svn/error.log
make[1]: Entering directory `/home/paulo/Software/spatial/grass-addons/gui/wxpython/wx.metadata/config'
make[1]: Leaving directory `/home/paulo/Software/spatial/grass-addons/gui/wxpython/wx.metadata/config'
make -C r.info.iso || echo /home/paulo/Software/spatial/grass-addons/gui/wxpython/wx.metadata/r.info.iso >> /usr/local/grass7/grass-7.1.svn/error.log
make[1]: Entering directory `/home/paulo/Software/spatial/grass-addons/gui/wxpython/wx.metadata/r.info.iso'
GISRC=/usr/local/grass7/grass-7.1.svn/demolocation/.grassrc71 GISBASE=/usr/local/grass7/grass-7.1.svn PATH="/usr/local/grass7/grass-7.1.svn/bin:/usr/local/grass7/grass-7.1.svn/bin:/usr/local/grass7/grass-7.1.svn/scripts:$PATH" PYTHONPATH="/usr/local/grass7/grass-7.1.svn/etc/python:/usr/local/grass7/grass-7.1.svn/gui/wxpython:$PYTHONPATH" LD_LIBRARY_PATH="/usr/local/grass7/grass-7.1.svn/bin:/usr/local/grass7/grass-7.1.svn/scripts:/usr/local/grass7/grass-7.1.svn/lib:/usr/local/grass7/grass-7.1.svn/lib::/lib:/usr/local/lib:/usr/local/gdal/lib" LC_ALL=C g.parser -t r.info.iso.py | sed s/\"/\\\\\"/g | sed 's/.*/_("&")/' > /usr/local/grass7/grass-7.1.svn/locale/scriptstrings/r.info.iso_to_translate.c
/bin/sh: 1: cannot create /usr/local/grass7/grass-7.1.svn/locale/scriptstrings/r.info.iso_to_translate.c: Directory nonexistent
make[1]: [/usr/local/grass7/grass-7.1.svn/locale/scriptstrings/r.info.iso_to_translate.c] Error 2 (ignored)
make[1]: Leaving directory `/home/paulo/Software/spatial/grass-addons/gui/wxpython/wx.metadata/r.info.iso'
make -C v.info.iso || echo /home/paulo/Software/spatial/grass-addons/gui/wxpython/wx.metadata/v.info.iso >> /usr/local/grass7/grass-7.1.svn/error.log
make[1]: Entering directory `/home/paulo/Software/spatial/grass-addons/gui/wxpython/wx.metadata/v.info.iso'
GISRC=/usr/local/grass7/grass-7.1.svn/demolocation/.grassrc71 GISBASE=/usr/local/grass7/grass-7.1.svn PATH="/usr/local/grass7/grass-7.1.svn/bin:/usr/local/grass7/grass-7.1.svn/bin:/usr/local/grass7/grass-7.1.svn/scripts:$PATH" PYTHONPATH="/usr/local/grass7/grass-7.1.svn/etc/python:/usr/local/grass7/grass-7.1.svn/gui/wxpython:$PYTHONPATH" LD_LIBRARY_PATH="/usr/local/grass7/grass-7.1.svn/bin:/usr/local/grass7/grass-7.1.svn/scripts:/usr/local/grass7/grass-7.1.svn/lib:/usr/local/grass7/grass-7.1.svn/lib::/lib:/usr/local/lib:/usr/local/gdal/lib" LC_ALL=C g.parser -t v.info.iso.py | sed s/\"/\\\\\"/g | sed 's/.*/_("&")/' > /usr/local/grass7/grass-7.1.svn/locale/scriptstrings/v.info.iso_to_translate.c
/bin/sh: 1: cannot create /usr/local/grass7/grass-7.1.svn/locale/scriptstrings/v.info.iso_to_translate.c: Directory nonexistent
make[1]: [/usr/local/grass7/grass-7.1.svn/locale/scriptstrings/v.info.iso_to_translate.c] Error 2 (ignored)
make[1]: Leaving directory `/home/paulo/Software/spatial/grass-addons/gui/wxpython/wx.metadata/v.info.iso'
make -C t.info.iso || echo /home/paulo/Software/spatial/grass-addons/gui/wxpython/wx.metadata/t.info.iso >> /usr/local/grass7/grass-7.1.svn/error.log
make[1]: Entering directory `/home/paulo/Software/spatial/grass-addons/gui/wxpython/wx.metadata/t.info.iso'
GISRC=/usr/local/grass7/grass-7.1.svn/demolocation/.grassrc71 GISBASE=/usr/local/grass7/grass-7.1.svn PATH="/usr/local/grass7/grass-7.1.svn/bin:/usr/local/grass7/grass-7.1.svn/bin:/usr/local/grass7/grass-7.1.svn/scripts:$PATH" PYTHONPATH="/usr/local/grass7/grass-7.1.svn/etc/python:/usr/local/grass7/grass-7.1.svn/gui/wxpython:$PYTHONPATH" LD_LIBRARY_PATH="/usr/local/grass7/grass-7.1.svn/bin:/usr/local/grass7/grass-7.1.svn/scripts:/usr/local/grass7/grass-7.1.svn/lib:/usr/local/grass7/grass-7.1.svn/lib::/lib:/usr/local/lib:/usr/local/gdal/lib" LC_ALL=C g.parser -t t.info.iso.py | sed s/\"/\\\\\"/g | sed 's/.*/_("&")/' > /usr/local/grass7/grass-7.1.svn/locale/scriptstrings/t.info.iso_to_translate.c
/bin/sh: 1: cannot create /usr/local/grass7/grass-7.1.svn/locale/scriptstrings/t.info.iso_to_translate.c: Directory nonexistent
make[1]: [/usr/local/grass7/grass-7.1.svn/locale/scriptstrings/t.info.iso_to_translate.c] Error 2 (ignored)
make[1]: Leaving directory `/home/paulo/Software/spatial/grass-addons/gui/wxpython/wx.metadata/t.info.iso'
make -C db.csw.admin || echo /home/paulo/Software/spatial/grass-addons/gui/wxpython/wx.metadata/db.csw.admin >> /usr/local/grass7/grass-7.1.svn/error.log
make[1]: Entering directory `/home/paulo/Software/spatial/grass-addons/gui/wxpython/wx.metadata/db.csw.admin'
if [ "/usr/local/grass7/grass-7.1.svn/scripts/db.csw.admin" != "" ] ; then GISRC=/usr/local/grass7/grass-7.1.svn/demolocation/.grassrc71 GISBASE=/usr/local/grass7/grass-7.1.svn PATH="/usr/local/grass7/grass-7.1.svn/bin:/usr/local/grass7/grass-7.1.svn/bin:/usr/local/grass7/grass-7.1.svn/scripts:$PATH" PYTHONPATH="/usr/local/grass7/grass-7.1.svn/etc/python:/usr/local/grass7/grass-7.1.svn/gui/wxpython:$PYTHONPATH" LD_LIBRARY_PATH="/usr/local/grass7/grass-7.1.svn/bin:/usr/local/grass7/grass-7.1.svn/scripts:/usr/local/grass7/grass-7.1.svn/lib:/usr/local/grass7/grass-7.1.svn/lib::/lib:/usr/local/lib:/usr/local/gdal/lib" LC_ALL=C /usr/local/grass7/grass-7.1.svn/scripts/db.csw.admin --html-description < /dev/null | grep -v '</body>\|</html>' > db.csw.admin.tmp.html ; fi
   File "/usr/local/grass7/grass-7.1.svn/scripts/db.csw.admin", line 127, in <module>
     from cswutil import *
ImportError: No module named cswutil
make[1]: *** [db.csw.admin.tmp.html] Error 1
rm db.csw.admin.tmp.html
make[1]: Leaving directory `/home/paulo/Software/spatial/grass-addons/gui/wxpython/wx.metadata/db.csw.admin'
make -C db.csw.run || echo /home/paulo/Software/spatial/grass-addons/gui/wxpython/wx.metadata/db.csw.run >> /usr/local/grass7/grass-7.1.svn/error.log
make[1]: Entering directory `/home/paulo/Software/spatial/grass-addons/gui/wxpython/wx.metadata/db.csw.run'
GISRC=/usr/local/grass7/grass-7.1.svn/demolocation/.grassrc71 GISBASE=/usr/local/grass7/grass-7.1.svn PATH="/usr/local/grass7/grass-7.1.svn/bin:/usr/local/grass7/grass-7.1.svn/bin:/usr/local/grass7/grass-7.1.svn/scripts:$PATH" PYTHONPATH="/usr/local/grass7/grass-7.1.svn/etc/python:/usr/local/grass7/grass-7.1.svn/gui/wxpython:$PYTHONPATH" LD_LIBRARY_PATH="/usr/local/grass7/grass-7.1.svn/bin:/usr/local/grass7/grass-7.1.svn/scripts:/usr/local/grass7/grass-7.1.svn/lib:/usr/local/grass7/grass-7.1.svn/lib::/lib:/usr/local/lib:/usr/local/gdal/lib" LC_ALL=C g.parser -t db.csw.run.py | sed s/\"/\\\\\"/g | sed 's/.*/_("&")/' > /usr/local/grass7/grass-7.1.svn/locale/scriptstrings/db.csw.run_to_translate.c
/bin/sh: 1: cannot create /usr/local/grass7/grass-7.1.svn/locale/scriptstrings/db.csw.run_to_translate.c: Directory nonexistent
make[1]: [/usr/local/grass7/grass-7.1.svn/locale/scriptstrings/db.csw.run_to_translate.c] Error 2 (ignored)
make[1]: Leaving directory `/home/paulo/Software/spatial/grass-addons/gui/wxpython/wx.metadata/db.csw.run'
make -C db.csw.harvest || echo /home/paulo/Software/spatial/grass-addons/gui/wxpython/wx.metadata/db.csw.harvest >> /usr/local/grass7/grass-7.1.svn/error.log
make[1]: Entering directory `/home/paulo/Software/spatial/grass-addons/gui/wxpython/wx.metadata/db.csw.harvest'
GISRC=/usr/local/grass7/grass-7.1.svn/demolocation/.grassrc71 GISBASE=/usr/local/grass7/grass-7.1.svn PATH="/usr/local/grass7/grass-7.1.svn/bin:/usr/local/grass7/grass-7.1.svn/bin:/usr/local/grass7/grass-7.1.svn/scripts:$PATH" PYTHONPATH="/usr/local/grass7/grass-7.1.svn/etc/python:/usr/local/grass7/grass-7.1.svn/gui/wxpython:$PYTHONPATH" LD_LIBRARY_PATH="/usr/local/grass7/grass-7.1.svn/bin:/usr/local/grass7/grass-7.1.svn/scripts:/usr/local/grass7/grass-7.1.svn/lib:/usr/local/grass7/grass-7.1.svn/lib::/lib:/usr/local/lib:/usr/local/gdal/lib" LC_ALL=C g.parser -t db.csw.harvest.py | sed s/\"/\\\\\"/g | sed 's/.*/_("&")/' > /usr/local/grass7/grass-7.1.svn/locale/scriptstrings/db.csw.harvest_to_translate.c
/bin/sh: 1: cannot create /usr/local/grass7/grass-7.1.svn/locale/scriptstrings/db.csw.harvest_to_translate.c: Directory nonexistent
make[1]: [/usr/local/grass7/grass-7.1.svn/locale/scriptstrings/db.csw.harvest_to_translate.c] Error 2 (ignored)
make[1]: Leaving directory `/home/paulo/Software/spatial/grass-addons/gui/wxpython/wx.metadata/db.csw.harvest'
make -C g.gui.cswbrowser || echo /home/paulo/Software/spatial/grass-addons/gui/wxpython/wx.metadata/g.gui.cswbrowser >> /usr/local/grass7/grass-7.1.svn/error.log
make[1]: Entering directory `/home/paulo/Software/spatial/grass-addons/gui/wxpython/wx.metadata/g.gui.cswbrowser'
if [ "/usr/local/grass7/grass-7.1.svn/scripts/g.gui.cswbrowser" != "" ] ; then GISRC=/usr/local/grass7/grass-7.1.svn/demolocation/.grassrc71 GISBASE=/usr/local/grass7/grass-7.1.svn PATH="/usr/local/grass7/grass-7.1.svn/bin:/usr/local/grass7/grass-7.1.svn/bin:/usr/local/grass7/grass-7.1.svn/scripts:$PATH" PYTHONPATH="/usr/local/grass7/grass-7.1.svn/etc/python:/usr/local/grass7/grass-7.1.svn/gui/wxpython:$PYTHONPATH" LD_LIBRARY_PATH="/usr/local/grass7/grass-7.1.svn/bin:/usr/local/grass7/grass-7.1.svn/scripts:/usr/local/grass7/grass-7.1.svn/lib:/usr/local/grass7/grass-7.1.svn/lib::/lib:/usr/local/lib:/usr/local/gdal/lib" LC_ALL=C /usr/local/grass7/grass-7.1.svn/scripts/g.gui.cswbrowser --html-description < /dev/null | grep -v '</body>\|</html>' > g.gui.cswbrowser.tmp.html ; fi
   File "/usr/local/grass7/grass-7.1.svn/scripts/g.gui.cswbrowser", line 22, in <module>
     from cswlib import CSWBrowserPanel, CSWConnectionPanel
ImportError: No module named cswlib
make[1]: *** [g.gui.cswbrowser.tmp.html] Error 1
rm g.gui.cswbrowser.tmp.html
make[1]: Leaving directory `/home/paulo/Software/spatial/grass-addons/gui/wxpython/wx.metadata/g.gui.cswbrowser'
make -C g.gui.metadata || echo /home/paulo/Software/spatial/grass-addons/gui/wxpython/wx.metadata/g.gui.metadata >> /usr/local/grass7/grass-7.1.svn/error.log
make[1]: Entering directory `/home/paulo/Software/spatial/grass-addons/gui/wxpython/wx.metadata/g.gui.metadata'
if [ "/usr/local/grass7/grass-7.1.svn/scripts/g.gui.metadata" != "" ] ; then GISRC=/usr/local/grass7/grass-7.1.svn/demolocation/.grassrc71 GISBASE=/usr/local/grass7/grass-7.1.svn PATH="/usr/local/grass7/grass-7.1.svn/bin:/usr/local/grass7/grass-7.1.svn/bin:/usr/local/grass7/grass-7.1.svn/scripts:$PATH" PYTHONPATH="/usr/local/grass7/grass-7.1.svn/etc/python:/usr/local/grass7/grass-7.1.svn/gui/wxpython:$PYTHONPATH" LD_LIBRARY_PATH="/usr/local/grass7/grass-7.1.svn/bin:/usr/local/grass7/grass-7.1.svn/scripts:/usr/local/grass7/grass-7.1.svn/lib:/usr/local/grass7/grass-7.1.svn/lib::/lib:/usr/local/lib:/usr/local/gdal/lib" LC_ALL=C /usr/local/grass7/grass-7.1.svn/scripts/g.gui.metadata --html-description < /dev/null | grep -v '</body>\|</html>' > g.gui.metadata.tmp.html ; fi
   File "/usr/local/grass7/grass-7.1.svn/scripts/g.gui.metadata", line 35, in <module>
     import mdgrass
ImportError: No module named mdgrass
make[1]: *** [g.gui.metadata.tmp.html] Error 1
rm g.gui.metadata.tmp.html
make[1]: Leaving directory `/home/paulo/Software/spatial/grass-addons/gui/wxpython/wx.metadata/g.gui.metadata'
