[GRASS-dev] wx.metadata ready for testing
Martin Landa
landa.martin at gmail.com
Wed Oct 7 02:48:15 PDT 2015
2015-10-07 10:14 GMT+02:00 Paulo van Breugel <p.vanbreugel at gmail.com>:
> make -C mdlib || echo
> /home/paulo/Software/spatial/grass-addons/gui/wxpython/wx.metadata/mdlib >>
> /usr/local/grass7/grass-7.1.svn/error.log
it seems to me that `g.extension` is trying to install addons to
/usr/local. Are you sure that you are not using `-s` flag or
GRASS_ADDON_BASE which points to /usr/local/grass7 ... ?
Martin
> rm g.gui.cswbrowser.tmp.html
> make[1]: Leaving directory
> `/home/paulo/Software/spatial/grass-addons/gui/wxpython/wx.metadata/g.gui.cswbrowser'
> make -C g.gui.metadata || echo
> /home/paulo/Software/spatial/grass-addons/gui/wxpython/wx.metadata/g.gui.metadata
> make[1]: Entering directory
> `/home/paulo/Software/spatial/grass-addons/gui/wxpython/wx.metadata/g.gui.metadata'
> if [ "/usr/local/grass7/grass-7.1.svn/scripts/g.gui.metadata" != "" ] ; then
> GISRC=/usr/local/grass7/grass-7.1.svn/demolocation/.grassrc71
> GISBASE=/usr/local/grass7/grass-7.1.svn
> PATH="/usr/local/grass7/grass-7.1.svn/bin:/usr/local/grass7/grass-7.1.svn/bin:/usr/local/grass7/grass-7.1.svn/scripts:$PATH"
> PYTHONPATH="/usr/local/grass7/grass-7.1.svn/etc/python:/usr/local/grass7/grass-7.1.svn/gui/wxpython:$PYTHONPATH"
> LD_LIBRARY_PATH="/usr/local/grass7/grass-7.1.svn/bin:/usr/local/grass7/grass-7.1.svn/scripts:/usr/local/grass7/grass-7.1.svn/lib:/usr/local/grass7/grass-7.1.svn/lib::/lib:/usr/local/lib:/usr/local/gdal/lib"
> LC_ALL=C /usr/local/grass7/grass-7.1.svn/scripts/g.gui.metadata
> --html-description < /dev/null | grep -v '</body>\|</html>' >
> g.gui.metadata.tmp.html ; fi
> Traceback (most recent call last):
> File "/usr/local/grass7/grass-7.1.svn/scripts/g.gui.metadata", line 35, in
> <module>
> import mdgrass
> ImportError: No module named mdgrass
> make[1]: *** [g.gui.metadata.tmp.html] Error 1
> rm g.gui.metadata.tmp.html
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
