[GRASS-dev] [GRASS GIS] #2735: t.rast.mapcalc input problem
trac at osgeo.org
Wed Oct 7 01:33:37 PDT 2015
Reporter: leohardtke | Owner: grass-dev@…
Type: defect | Status: reopened
Priority: normal | Milestone: 7.0.1
Component: Temporal | Version: svn-trunk
Resolution: | Keywords: t.rast.mapcalc
CPU: Unspecified | Platform: Linux
Changes (by huhabla):
* status: closed => reopened
* resolution: fixed =>
Comment:
This bug was not fixed in t.rast.mapcalc. A similar bug was fixed in
t.rast.extract.
However, fixing the bug in t.rast.mapcalc is more difficult since it uses
a simple search and replace approach to substitute the input STRDS with
map names and is not aware of what a space time dataset is. If the names
of input and output space time datasets are include each other, then the
module does not work properly. Choosing a specific order of the input
STRDS in the input parameter (i.e: input=ndvi_smooth,QA_mask,ndvi) may
reduce the risk of wrong substitution.
However, please use t.rast.algebra instead. This module has other issues
but is able to correctly identify space time datasets.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2735#comment:3>
