[GRASS-dev] [GRASS GIS] #2734: v.distance: 3d point inside area is classified as outside
GRASS GIS trac at osgeo.org
Wed Oct 7 07:02:33 PDT 2015
  Reporter:  annakrat  |      Owner:  grass-dev@…
      Type:  defect    |     Status:  new
  Priority:  normal    |  Milestone:  7.0.2
 Component:  Vector    |    Version:  svn-trunk
Resolution:            |   Keywords:  v.distance, box
       CPU:  All       |   Platform:  All
Comment (by wenzeslaus):
 On Wed, Oct 7, 2015 at 4:32 AM, Moritz Lennert wrote at
 [https://lists.osgeo.org/pipermail/grass-user/2015-October/073089.html
 grass-user]:
 > I have the feeling that the second proposed solution, i.e. "introduce a
 2D version of the Vect_point_in_box function which checks x and y only" is
 the better long-run solution.
 Good idea. I could use this, e.g. in
 [source:grass/trunk/vector/v.decimate/main.c?rev=66387#L86 v.decimate]
 where I have now `point_in_region_2d()` and `point_in_region_3d`. I'm
 using `Cell_head` as the region/bbox, but it doesn't contain any info
 whether it is 2D or 3D, if something like `depths=0` (perhaps wrapped in
 `G_is_cell_head_3d()`) would tell if it is 3D, then I could have just
 `point_in_region()`.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2734#comment:1>
