[GRASS-dev] [GRASS GIS] #2750: LZ4 when writing raster rows; better than double I/O bound r.mapcalc speed
trac at osgeo.org
Thu Oct 8 06:45:37 PDT 2015
Reporter: sprice | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.1.0
Component: Raster | Version: svn-trunk
Resolution: | Keywords: ZLIB LZ4 ZSTD
CPU: OSX/Intel | Platform: MacOSX
Comment (by wenzeslaus):
Replying to [comment:6 wenzeslaus]:
> Replying to [comment:5 sprice]:
> > I just uploaded a new version of the code that shouldn't fail any
additional unit tests, and I've added unit tests to r.compress that test
reading/writing the different compression schemes.
> Nice. Runs for me as well.
Bad news. Only the r.compress tests runs well for me. I messed up the
environmental variables.
Now (with `export GRASS_INT_LZ4=1`) I'm getting fails from various tests.
Wrong values in the result (for example):
./raster/r.series.interp/testsuite/interp_test.py
FAIL: test_infile (__main__.InterpolationTest)
AssertionError: The actual maximum (269) is greater than the reference
one (200) for raster map prec_2 (with minimum 200)
Possible segmentation faults:
./raster/r.gwflow/testsuite/validation_7x7_grid.py
FAIL: test_transient (__main__.Validation7x7Grid)
AssertionError: Running <r.gwflow> module ended with non-zero return code
(-11)
./temporal/t.rast.univar/testsuite/test.t.rast.univar.sh
grass.exceptions.CalledModuleError: Module run ['r.univar', '-ge',
u'map=prec_1 at __temporal_t_rast_univar_test.t. rast.univar'] ended with
error
Process ended with non-zero return code -11.
With the changes applied but with default settings (`unset
GRASS_INT_LZ4`), I'm getting the same results as at the
[http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2015-10-08-07-00/report_for_nc_basic_spm_grass7_nc/testfiles.html
test server]. r.compress test runs well in both cases.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2750#comment:7>
