[GRASS-dev] r.stream.watersheds & r.stream.variables add-on
Giuseppe Amatulli giuseppe.amatulli at gmail.com
Thu Oct 8 08:45:26 PDT 2015
we have developed 2 grass add-on
"r.stream.watersheds" that performs (for each single grid cell of a stream
network) the sub-watershed delineation based on the drainage direction and
a gridded stream network
"r.stream.variables" which will calculate and relate the
upstream-contributing environmental conditions (contiguous layers, e.g.
air-temperature, elevation, land use, etc.) to each stream grid cell.
https://trac.osgeo.org/grass/browser/grass-addons/grass7/raster/r.stream.variables
The main output is thus an environmental variable that follows the river
continuum from the source to the mouth of a river, and can be used in e.g.
species distribution models (or any ecological model).
https://trac.osgeo.org/grass/browser/grass-addons/grass7/raster/r.stream.watersheds
A publication has been submitted and will be soon on line.
Right now the add-on is in Bash ( it was easier to adapt the same script
that we use in the high-performace-computing for the massive computation)
but we are planing to translate in  python.
While converting the add-ons into python, we want to provide users the
possibility to use these tools. We would like to fill in the manual
page, and provide a short-term work-around (copy the .sh-files into
/scripts, as this works perfectly).
Meanwhile, we work on the python version and release it as soon as
possible. Does this sound reasonable?
Is there a way we could have the manual page for these add-ons online?
Thanks and best wishes,
Giuseppe & Sami
Giuseppe Amatulli, Ph.D.
Department of Ecology and Evolutionary Biology, Yale University.
Jetz Lab, OML Room 405
P.O. Box 208106
165 PROSPECT ST
New Haven, CT 06520-8106
Teaching: spatial-ecology.net
Work:  http://sbsc.yale.edu/giuseppe-amatulli
<http://www.spatial-ecology.net>
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151008/e35df14b/attachment.html>
