[GRASS-dev] GRASS will not not find laslib
Michael Barton
Michael.Barton at asu.edu
Thu Oct 8 15:26:32 PDT 2015
I built boost with both bjam and b2 for i86_64. Here are the setups I used:
cd /Users/Shared/grass_dev/boost_1_59_0
edit /Users/cmbarton/grass_source/LAS/boost_1_59_0/tools/build/src/tools/darwin.jam to delete -gdwarf-2 ]
export CXXFLAGS=-stdlib=libstdc++
./bootstrap.sh --prefix=/Users/cmbarton/grass_source/LAS/boostlib --without-libraries=python
## attempt 1
./bjam variant=release link=static --without-mpi -j4 macosx-version=10.7 macosx-version-min=10.7 architecture=x86 address-model=64 install
## attempt 2
./b2 variant=release link=static --without-mpi -j4 macosx-version=10.7 macosx-version-min=10.7 cxxflags="-arch x86_64"
I built liblas for i86_64. I initially set the prefix to put all the liblas files into a local directory where I could get them for packaging. Then I did it again letting them go into /usr/local. In all cases I get this same error. This is with installing it into a nice local folder.
xport BOOST_ROOT="/Users/cmbarton/grass_source/LAS/boostlib"
export BOOST_INCLUDEDIR="/Users/cmbarton/grass_source/LAS/boostlib/include"
cmake -G "Unix Makefiles" \
-D CMAKE_INSTALL_PREFIX="/Users/cmbarton/grass_source/LAS/liblasdist" \
-D CMAKE_OSX_ARCHITECTURES="x86_64" \
-D CMAKE_OSX_SYSROOT="/Developer/SDKs/MacOSX10.7.sdk" \
-D GDAL_CONFIG="/Library/Frameworks/GDAL.framework/Programs/gdal-config" \
-D GDAL_INCLUDE_DIR="/Library/Frameworks/GDAL.framework/Headers" \
-D GDAL_LIBRARY="/Library/Frameworks/GDAL.framework/unix/lib/libgdal.dylib" \
-D GEOTIFF_INCLUDE_DIR="/Library/Frameworks/UnixImageIO.framework/unix/include" \
-D GEOTIFF_LIBRARY="/Library/Frameworks/UnixImageIO.framework/unix/lib/libgeotiff.dylib" \
-D TIFF_INCLUDE_DIR="/Library/Frameworks/UnixImageIO.framework/Headers" \
-D TIFF_LIBRARY="/Library/Frameworks/UnixImageIO.framework/unix/lib/libtiff.dylib" \
-D CMAKE_VERBOSE_MAKEFILE=true ../
Here is the GRASS configure error:
1 warning generated.
configure:6164: checking whether to use libLAS
configure:6181: checking for liblas-config
configure:6238: gcc -o conftest -g -O2 -arch i386 -arch x86_64 -isysroot /Developer/SDKs/MacOSX10.7.sdk -I/usr/local/include -I/usr/local/include -I/Library/Frameworks/GDAL.framework/Headers -I/Library/Frameworks/UnixImageIO.framework/unix/include -I/Library/Frameworks/UnixImageIO.framework/Headers -arch i386 -arch x86_64 -isysroot /Developer/SDKs/MacOSX10.7.sdk -L/usr/local/lib conftest.c -L/usr/local/lib -llas -llas_c -L/Users/cmbarton/grass_source/LAS/boostlib/lib /Users/cmbarton/grass_source/LAS/boostlib/lib/libboost_program_options.a /Users/cmbarton/grass_source/LAS/boostlib/lib/libboost_thread.a /Library/Frameworks/GDAL.framework/unix/lib/libgdal.dylib /Library/Frameworks/UnixImageIO.framework/unix/lib/libgeotiff.dylib /Library/Frameworks/UnixImageIO.framework/unix/lib/libtiff.dylib 1>&5
ld: warning: ld: warning: ld: warning: ignoring file /usr/local/lib/liblas.dylib, file was built for x86_64 which is not the architecture being linked (i386): /usr/local/lib/liblas.dylibignoring file /usr/local/lib/liblas_c.dylib, file was built for x86_64 which is not the architecture being linked (i386): /usr/local/lib/liblas_c.dylibignoring file /Users/cmbarton/grass_source/LAS/boostlib/lib/libboost_program_options.a, file was built for archive which is not the architecture being linked (i386): /Users/cmbarton/grass_source/LAS/boostlib/lib/libboost_program_options.a
ld: warning: ignoring file /Users/cmbarton/grass_source/LAS/boostlib/lib/libboost_thread.a, file was built for archive which is not the architecture being linked (i386): /Users/cmbarton/grass_source/LAS/boostlib/lib/libboost_thread.a
Undefined symbols for architecture i386:
"_LASReader_Create", referenced from:
_main in conftest-68543b.o
ld: symbol(s) not found for architecture i386
clang: error: linker command failed with exit code 1 (use -v to see invocation)
configure: failed program was:
#line 6231 "configure"
#include "confdefs.h"
#include <liblas/capi/liblas.h>
int main() {
LASReader_Create("foo");
; return 0; }
Anna, I'm happy to pass on tricks once I get them to actually work. I'm keeping notes.
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Oct 8, 2015, at 3:07 PM, Anna Petrášová <kratochanna at gmail.com<mailto:kratochanna at gmail.com>> wrote:
On Thu, Oct 8, 2015 at 5:24 PM, Michael Barton <Michael.Barton at asu.edu<mailto:Michael.Barton at asu.edu>> wrote:
With a lot of effort and some help, I've rebuilt liblas with new GDAL. Now GRASS will not find liblas with the same configuration script that I've used before. Here it is:
Was there some specific trick that you could share?
./configure --with-macosx-sdk=/Developer/SDKs/MacOSX10.7.sdk --with-freetype --with-freetype-includes="/Library/Frameworks/FreeType.framework/unix/include/freetype2 /Library/Frameworks/FreeType.framework/unix/include" --with-freetype-libs=/Library/Frameworks/FreeType.framework/unix/lib --with-gdal=/Library/Frameworks/GDAL.framework/Programs/gdal-config --with-proj --with-proj-includes=/Library/Frameworks/PROJ.framework/unix/include --with-proj-libs=/Library/Frameworks/PROJ.framework/unix/lib --with-proj-share=/Library/Frameworks/PROJ.framework/Resources/proj --with-geos=/Library/Frameworks/GEOS.framework/Versions/3/unix/bin/geos-config --with-jpeg-includes=/Library/Frameworks/UnixImageIO.framework/unix/include --with-jpeg-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib --with-png-includes=/Library/Frameworks/UnixImageIO.framework/unix/include --with-png-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib --with-tiff-includes=/Library/Frameworks/UnixImageIO.framework/unix/include --with-tiff-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib --with-cairo --with-cairo-includes="/Library/Frameworks/cairo.framework/unix/include/cairo /Library/Frameworks/cairo.framework/unix/include" --with-cairo-libs=/Library/Frameworks/cairo.framework/unix/lib --with-cairo-ldflags="-lcairo" --without-postgres --without-mysql --with-sqlite --with-sqlite-libs=/Library/Frameworks/SQLite3.framework/unix/lib --with-sqlite-includes=/Library/Frameworks/SQLite3.framework/unix/include --with-fftw-includes=/Library/Frameworks/FFTW3.framework/unix/include --with-fftw-libs=/Library/Frameworks/FFTW3.framework/unix/lib --with-x --with-cxx --with-opengl=aqua --without-readline --prefix=/Applications --enable-macosx-app --with-python --with-wxwidgets=/usr/local/lib/wxPython-unicode-2.8.12.1/bin/wx-config --with-tcltk-includes="/Library/Frameworks/Tcl.framework/Headers /Library/Frameworks/Tk.framework/Headers /Library/Frameworks/Tk.framework/PrivateHeaders" --with-tcltk-libs="/usr/local/tcltk_active/lib" --with-macosx-archs="i386 x86_64" --with-liblas="/usr/local/bin/liblas-config" --with-opencl --with-nls --with-libs=/usr/local/lib --with-includes=/usr/local/include
FWIW, here is the uninformative error. Any thoughts???
There should be a log file from the configuration with more details, not sure what's its name though.
checking for liblas-config... /usr/local/bin/liblas-config
configure: error: *** Unable to locate libLAS library.
(yes liblas-config is exactly where I say it is)
Michael
C. Michael Barton
voice: 480-965-6262<tel:480-965-6262> (SHESC), 480-965-8130<tel:480-965-8130>/727-9746 (CSDC)
fax: 480-965-7671<tel:480-965-7671> (SHESC), 480-727-0709<tel:480-727-0709> (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu<http://csdc.asu.edu/>
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151008/8eb69b26/attachment-0001.html>
