[GRASS-dev] GRASS will not not find laslib
Anna Petrášová
kratochanna at gmail.com
Thu Oct 8 16:07:17 PDT 2015
On Thu, Oct 8, 2015 at 6:26 PM, Michael Barton <Michael.Barton at asu.edu>
wrote:
> I built boost with both bjam and b2 for i86_64. Here are the setups I
> used:
> cd /Users/Shared/grass_dev/boost_1_59_0
> edit
> /Users/cmbarton/grass_source/LAS/boost_1_59_0/tools/build/src/tools/darwin.jam
> to delete -gdwarf-2 ]
> export CXXFLAGS=-stdlib=libstdc++
> ./bootstrap.sh --prefix=/Users/cmbarton/grass_source/LAS/boostlib
> --without-libraries=python
> ## attempt 1
> ./bjam variant=release link=static --without-mpi -j4 macosx-version=10.7
> macosx-version-min=10.7 architecture=x86 address-model=64 install
> ## attempt 2
> ./b2 variant=release link=static --without-mpi -j4 macosx-version=10.7
> macosx-version-min=10.7 cxxflags="-arch x86_64"
> I built liblas for i86_64. I initially set the prefix to put all the
> liblas files into a local directory where I could get them for packaging.
> Then I did it again letting them go into /usr/local. In all cases I get
> this same error. This is with installing it into a nice local folder.
> xport BOOST_ROOT="/Users/cmbarton/grass_source/LAS/boostlib"
> export BOOST_INCLUDEDIR="/Users/cmbarton/grass_source/LAS/boostlib/include"
> cmake -G "Unix Makefiles" \
> -D CMAKE_INSTALL_PREFIX="/Users/cmbarton/grass_source/LAS/liblasdist" \
> -D CMAKE_OSX_ARCHITECTURES="x86_64" \
> -D CMAKE_OSX_SYSROOT="/Developer/SDKs/MacOSX10.7.sdk" \
> -D GDAL_CONFIG="/Library/Frameworks/GDAL.framework/Programs/gdal-config" \
> -D GDAL_INCLUDE_DIR="/Library/Frameworks/GDAL.framework/Headers" \
> -D
> GDAL_LIBRARY="/Library/Frameworks/GDAL.framework/unix/lib/libgdal.dylib" \
> -D
> GEOTIFF_INCLUDE_DIR="/Library/Frameworks/UnixImageIO.framework/unix/include"
> -D
> GEOTIFF_LIBRARY="/Library/Frameworks/UnixImageIO.framework/unix/lib/libgeotiff.dylib"
> -D TIFF_INCLUDE_DIR="/Library/Frameworks/UnixImageIO.framework/Headers" \
> -D
> TIFF_LIBRARY="/Library/Frameworks/UnixImageIO.framework/unix/lib/libtiff.dylib"
> -D CMAKE_VERBOSE_MAKEFILE=true ../
> Here is the GRASS configure error:
> 1 warning generated.
> configure:6164: checking whether to use libLAS
> configure:6181: checking for liblas-config
> configure:6238: gcc -o conftest -g -O2 -arch i386 -arch x86_64 -isysroot
> /Developer/SDKs/MacOSX10.7.sdk -I/usr/local/include -I/usr/local/include
> -I/Library/Frameworks/GDAL.framework/Headers
> -I/Library/Frameworks/UnixImageIO.framework/unix/include
> -I/Library/Frameworks/UnixImageIO.framework/Headers -arch i386 -arch
> x86_64 -isysroot /Developer/SDKs/MacOSX10.7.sdk -L/usr/local/lib
> conftest.c -L/usr/local/lib -llas -llas_c
> -L/Users/cmbarton/grass_source/LAS/boostlib/lib
> /Users/cmbarton/grass_source/LAS/boostlib/lib/libboost_program_options.a
> /Users/cmbarton/grass_source/LAS/boostlib/lib/libboost_thread.a
> /Library/Frameworks/UnixImageIO.framework/unix/lib/libtiff.dylib 1>&5
> ld: warning: ld: warning: ld: warning: ignoring file
> /usr/local/lib/liblas.dylib, file was built for x86_64 which is not the
> architecture being linked (i386): /usr/local/lib/liblas.dylibignoring file
> /usr/local/lib/liblas_c.dylib, file was built for x86_64 which is not the
> architecture being linked (i386): /usr/local/lib/liblas_c.dylibignoring
> file
> /Users/cmbarton/grass_source/LAS/boostlib/lib/libboost_program_options.a,
> file was built for archive which is not the architecture being linked
> (i386):
> /Users/cmbarton/grass_source/LAS/boostlib/lib/libboost_thread.a, file was
> built for archive which is not the architecture being linked (i386):
> Undefined symbols for architecture i386:
> "_LASReader_Create", referenced from:
> _main in conftest-68543b.o
> ld: symbol(s) not found for architecture i386
> clang: error: linker command failed with exit code 1 (use -v to see
> invocation)
> configure: failed program was:
> #line 6231 "configure"
> #include "confdefs.h"
> #include <liblas/capi/liblas.h>
> int main() {
> LASReader_Create("foo");
> ; return 0; }
> Anna, I'm happy to pass on tricks once I get them to actually work. I'm
> keeping notes.
Thanks! I wonder if the problem can't be the line in the liblas config:
how about this? (just a guess)
-D CMAKE_OSX_ARCHITECTURES="x86_64;i386"
> Michael
> ____________________
> C. Michael Barton
> Director, Center for Social Dynamics & Complexity
> Professor of Anthropology, School of Human Evolution & Social Change
> Head, Graduate Faculty in Complex Adaptive Systems Science
> Arizona State University
> voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
> fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
> www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
> On Oct 8, 2015, at 3:07 PM, Anna Petrášová <kratochanna at gmail.com> wrote:
> On Thu, Oct 8, 2015 at 5:24 PM, Michael Barton <Michael.Barton at asu.edu>
> wrote:
>> With a lot of effort and some help, I've rebuilt liblas with new GDAL.
>> Now GRASS will not find liblas with the same configuration script that I've
>> used before. Here it is:
> Was there some specific trick that you could share?
>> ./configure --with-macosx-sdk=/Developer/SDKs/MacOSX10.7.sdk
>> --with-freetype
>> --with-freetype-includes="/Library/Frameworks/FreeType.framework/unix/include/freetype2 /Library/Frameworks/FreeType.framework/unix/include"
>> --with-freetype-libs=/Library/Frameworks/FreeType.framework/unix/lib
>> --with-gdal=/Library/Frameworks/GDAL.framework/Programs/gdal-config
>> --with-proj
>> --with-proj-includes=/Library/Frameworks/PROJ.framework/unix/include
>> --with-proj-libs=/Library/Frameworks/PROJ.framework/unix/lib
>> --with-proj-share=/Library/Frameworks/PROJ.framework/Resources/proj
>> --with-geos=/Library/Frameworks/GEOS.framework/Versions/3/unix/bin/geos-config
>> --with-jpeg-includes=/Library/Frameworks/UnixImageIO.framework/unix/include
>> --with-jpeg-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib
>> --with-png-includes=/Library/Frameworks/UnixImageIO.framework/unix/include
>> --with-png-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib
>> --with-tiff-includes=/Library/Frameworks/UnixImageIO.framework/unix/include
>> --with-tiff-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib
>> --with-cairo
>> --with-cairo-includes="/Library/Frameworks/cairo.framework/unix/include/cairo /Library/Frameworks/cairo.framework/unix/include"
>> --with-cairo-libs=/Library/Frameworks/cairo.framework/unix/lib
>> --with-cairo-ldflags="-lcairo" --without-postgres --without-mysql
>> --with-sqlite
>> --with-sqlite-libs=/Library/Frameworks/SQLite3.framework/unix/lib
>> --with-sqlite-includes=/Library/Frameworks/SQLite3.framework/unix/include
>> --with-fftw-includes=/Library/Frameworks/FFTW3.framework/unix/include
>> --with-fftw-libs=/Library/Frameworks/FFTW3.framework/unix/lib --with-x
>> --with-cxx --with-opengl=aqua --without-readline --prefix=/Applications
>> --enable-macosx-app --with-python
>> --with-wxwidgets=/usr/local/lib/wxPython-unicode-2.8.12.1/bin/wx-config
>> --with-tcltk-includes="/Library/Frameworks/Tcl.framework/Headers
>> /Library/Frameworks/Tk.framework/Headers
>> /Library/Frameworks/Tk.framework/PrivateHeaders"
>> --with-tcltk-libs="/usr/local/tcltk_active/lib" --with-macosx-archs="i386
>> x86_64" --with-liblas="/usr/local/bin/liblas-config" --with-opencl
>> --with-nls --with-libs=/usr/local/lib --with-includes=/usr/local/include
>> FWIW, here is the uninformative error. Any thoughts???
> There should be a log file from the configuration with more details, not
> sure what's its name though.
>> checking for liblas-config... /usr/local/bin/liblas-config
>> configure: error: *** Unable to locate libLAS library.
>> (yes liblas-config is exactly where I say it is)
>> Michael
>> C. Michael Barton
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151008/875dad12/attachment-0001.html>
