[GRASS-dev] pygrass vector changes and backport planning (7.0.x? or 7.1.x?)
Markus Neteler
neteler at osgeo.org
Fri Oct 9 06:48:36 PDT 2015
On Fri, Oct 9, 2015 at 3:37 PM, Martin Landa <landa.martin at gmail.com> wrote:
> Hi,
> 2015-10-09 15:25 GMT+02:00 Pietro <peter.zamb at gmail.com>:
>> Thanks to Sören's work the pygrass vector library has been improved a
>> lot in trunk during the last weeks. So far they are not signed to be
>> backported [0].
> I would suggest to mark them to backported for 7.0.3 (ideally when
> 7.0.2 will be out).
>> I would like to understand when do you think these changes can be
>> ported to the stable branch and in which stable (7.0.X or 7.1.X)
>> relaease?
>> When do you think the next stable will be? :-)
> 7.0.2 as soon as possible (@Markus: what about next week?)
yes, please.
>> I would avoid to let the two branches differ too much, and I think we
>> should try to make trunk as much close to the release candidate as
>> possible if the changes seem to work.
> I would suggest to avoid heavy backporting to relbr70 (let's stay here
> with backports and minor changes). I would suggest to start preparing
> trunk to be switched to relbr_71 instead. Something like:
> * january 2016 (trunk -> relbr_71)
> * march 2016 - release 7.1
> Make sense to you?
Almost: aren't we keeping even numbers for stable (so, 7.2)? But we
have another thread open on that topic.
>> If you think that these changes should be ported to 7.1.X then probaly
>> I need a grass71 directory in grass_addons...
Let's avoid that somehow...
> Maybe you could modify your modules to detect if user is running 7.0
> or 7.1? Martin
Markus
