[GRASS-dev] pygrass vector changes and backport planning (7.0.x? or 7.1.x?)
Martin Landa
landa.martin at gmail.com
Fri Oct 9 06:37:31 PDT 2015
2015-10-09 15:25 GMT+02:00 Pietro <peter.zamb at gmail.com>:
> Thanks to Sören's work the pygrass vector library has been improved a
> lot in trunk during the last weeks. So far they are not signed to be
> backported [0].
I would suggest to mark them to backported for 7.0.3 (ideally when
7.0.2 will be out).
> I would like to understand when do you think these changes can be
> ported to the stable branch and in which stable (7.0.X or 7.1.X)
> relaease?
> When do you think the next stable will be? :-)
7.0.2 as soon as possible (@Markus: what about next week?)
> I would avoid to let the two branches differ too much, and I think we
> should try to make trunk as much close to the release candidate as
> possible if the changes seem to work.
I would suggest to avoid heavy backporting to relbr70 (let's stay here
with backports and minor changes). I would suggest to start preparing
trunk to be switched to relbr_71 instead. Something like:
* january 2016 (trunk -> relbr_71)
* march 2016 - release 7.1
Make sense to you?
> If you think that these changes should be ported to 7.1.X then probaly
> I need a grass71 directory in grass_addons...
Maybe you could modify your modules to detect if user is running 7.0
or 7.1? Martin
