[GRASS-dev] Planning of 7.0.2 release
Vaclav Petras
wenzeslaus at gmail.com
Fri Oct 9 10:06:49 PDT 2015
On Fri, Oct 9, 2015 at 9:47 AM, Martin Landa <landa.martin at gmail.com> wrote:
> * @Vaclav could you take a look at: r64877 ?
I added 2 different tests to trunk in r66449 (with manually created
results, so they doesn't depend on the current or previous implementation).
I also checked the results with int data when I did r64877, but since then
I used r.patch only once or twice with float data. Anyway, it seems safe to
backport, so I did that in r66450.
BTW, a nice test for r.patch could be written using random data and
comparison of the result with r.mapcalc. This is a good topic for anybody
interested in contributing a test.
Vaclav
https://trac.osgeo.org/grass/changeset/64877
https://trac.osgeo.org/grass/changeset/66449
https://trac.osgeo.org/grass/changeset/66450
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151009/49704a88/attachment.html>
