[GRASS-dev] [GRASS GIS] #2734: v.distance: 3d point inside area is classified as outside
trac at osgeo.org
Fri Oct 9 17:22:42 PDT 2015
Reporter: annakrat | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.2
Component: Vector | Version: svn-trunk
Resolution: | Keywords: v.distance, box
CPU: All | Platform: All
Comment (by wenzeslaus):
In r66459 I have added `Vect_point_in_box_2d()` function which is simply a
2D version of `Vect_point_in_box()` function which is 3D only. Alternative
would be to add one function which would optionally consider ''z''.
Using `Vect_point_in_box_2d()` and existing `with_z` logic I have tried to
fix this ticket and [https://lists.osgeo.org/pipermail/grass-
user/2015-July/072809.html reported issue] in r66460 in ''v.decimate''.
The test written for ''v.decimate'' would suggest that the change helped.
`Vect_point_in_box()` function is used a lot in the modules and very often
with hardcoded `0.0` as ''z'' parameter (and there might be also cases
when ''z'' is optionally zero). These should be replaced by the new
function or its universal alternative.
If `Vect_point_in_box_2d()` will be useful for ''v.decimate'' remains
unclear. Usage of `Vect_region_box()` function would be necessary.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2734#comment:2>
