[GRASS-dev] [GRASS GIS] #2750: LZ4 when writing raster rows; better than double I/O bound r.mapcalc speed
trac at osgeo.org
Sun Oct 18 11:47:31 PDT 2015
Reporter: sprice | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.1.0
Component: Raster | Version: svn-trunk
Resolution: | Keywords: ZLIB LZ4 ZSTD
CPU: OSX/Intel | Platform: MacOSX
Comment (by wenzeslaus):
Replying to [comment:17 sprice]:
> My main concern really is to get this merged & working before additional
changes such as those discussed in #2762 & #2349 make merging difficult.
That's right, but I would like to see some more testing before merging it.
Any chance somebody can do some? There are roughly three ways how to do
that after applying the patch:
* Set the variables (see above) and run the automatic tests on NC SPM and
report the results back.
* Run the benchmark Bash script attached to this ticket and compare with
results already reported.
* Set the variables and go through some your workflow and check the
results.
It seems to be that #2349 has all issues solved and committed, but lacks
feedback/testing. Conflicts with #2762 would be probably solvable, but
yes, it would be better to avoid them.
> What do you think about merging these changes now, and then upgrading
other I/O functions as you have time?
This can work. The refactoring I'm suggesting shouldn't be difficult at
the end, although we should take some time to do it right.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2750#comment:18>
