[GRASS-dev] GRASS will not not find laslib
Mon Oct 12 04:11:02 PDT 2015
Markus Neteler wrote:
> > But it has been obsoleted by wxpyimgview (a wxPython version), so I
> > see no reason not to simply remove it (and the wxWidgets configure
> > checks as well).
> Sounds reasonable for trunk.
Done in r66476 (wximgview) and r66477 (wxWidgets configure checks).
The latter may have an impact upon macosx/app/Makefile, which
references MACOSX_ARCHS_WXPYTHON (which no longer exists).
