[GRASS-dev] GRASS will not not find laslib
Markus Neteler neteler at osgeo.org
Fri Oct 9 06:54:13 PDT 2015
On Fri, Oct 9, 2015 at 6:49 AM, Glynn Clements <glynn at gclements.plus.com> wrote:
> Michael Barton wrote:
>> But wximgview would not compile with what appears to be a 32/64 bit conflict
> wximgview is (AFAIK) the only program which links against the
> wxWidgets libraries.
> But it has been obsoleted by wxpyimgview (a wxPython version), so I
> see no reason not to simply remove it (and the wxWidgets configure
> checks as well).
Sounds reasonable for trunk.
Markus
