[GRASS-dev] GRASS will not not find laslib
Thu Oct 8 21:49:47 PDT 2015
Michael Barton wrote:
> But wximgview would not compile with what appears to be a 32/64 bit conflict
wximgview is (AFAIK) the only program which links against the
wxWidgets libraries.
But it has been obsoleted by wxpyimgview (a wxPython version), so I
see no reason not to simply remove it (and the wxWidgets configure
checks as well).
