[GRASS-dev] Error reading raster data for row xxx (only when using r.series and t.rast.series)
Dylan Beaudette dylan.beaudette at gmail.com
Tue Oct 13 11:59:53 PDT 2015
On Tue, Oct 13, 2015 at 11:06 AM, Markus Neteler <neteler at osgeo.org> wrote:
> On Oct 13, 2015 7:01 PM, "Dylan Beaudette" <dylan.beaudette at gmail.com>
> wrote:
>> Hi Markus,
>> GRASS version information:
>>  ./configure  --without-odbc --without-mysql --with-readline
>> --with-cxx --enable-largefile --with-freetype
>> --with-freetype-includes=/usr/include/freetype2 --with-sqlite
>> --with-python --with-pthread
> I would not use pthread.
OK, good to know. I will re-compile without it and report back.
>> --with-geos=/usr/local/bin/geos-config
>> --without-opencl --with-opencl-includes=/usr/include/CL/
>> --with-postgres --with-postgres-includes=/usr/include/postgresql/
>> --with-postgres-libs=/usr/lib/
>> --with-proj-share=/usr/local/share/proj/
>> libgis Revision: 64732
> This is fairly old. Trunk is r66487.
> Can you update?
How does the "libgis" revision number relate to the version reported
when starting GRASS (e.g. SVN revision)?
>> libgis Date: 2015-02-24 16:54:05 -0800 (Tue, 24 Feb 2015)
>> PROJ.4: 4.8.0
>> GDAL/OGR: 2.0.0
>> GEOS: 3.4.2
>> SQLite: 3.7.9
> Best
> Markus
