[GRASS-dev] Error reading raster data for row xxx (only when using r.series and t.rast.series)
Sören Gebbert
soerengebbert at googlemail.com
Tue Oct 13 12:11:53 PDT 2015
Hi Dylan,
r.series is a module implemented in C with no relations to r.mapcalc.
t.rast.series is a Python module that makes use of r.series internally.
Best regards
Soeren
2015-10-13 21:06 GMT+02:00 Dylan Beaudette <dylan.beaudette at gmail.com>:
> On Tue, Oct 13, 2015 at 11:55 AM, Markus Neteler <neteler at osgeo.org> wrote:
>> On Tue, Oct 13, 2015 at 8:43 PM, Dylan Beaudette
>> <dylan.beaudette at gmail.com> wrote:
>>> Dangit... This is strange, just did an 'svn up', make distclean, make,
>>> make install, and now this:
>>> Welcome to GRASS GIS 7.1.svn (r66487)
>>> GRASS GIS homepage: http://grass.osgeo.org
>>> This version running through: Bash Shell (/bin/bash)
>>> Help is available with the command: g.manual -i
>>> See the licence terms with: g.version -c
>>> Start the GUI with: g.gui wxpython
>>> When ready to quit enter: exit
>>> GRASS 7.1.svn (prism):~/src/grass_trunk > g.version -r
>>> GRASS 7.1.svn (2015)
>>> libgis Revision: 64732
>>> libgis Date: 2015-02-24 16:54:05 -0800 (Tue, 24 Feb 2015)
>>> Has it been so long since I have compiled GRASS that I have missed
>>> something?
>> Yep:
>> https://trac.osgeo.org/grass/changeset/65591
>> "Prevent concurrent raster reads when a mask is present"
>> (which also got backported subsequently)
>>> I see that the libgis is still "old".
>> ... this is unrelated since the issue was in r.mapcalc (hence
>> affecting all modules using it).
>> The true revision number of interest is the one next to GRASS GIS
>> 7.1.svn (r66487).
>> I guess your issue is now solved.
>> Markus
> Maybe. I updated my local copy of grass_trunk last Monday, compiled,
> and experienced the issues with r.series and t.rast.series... in the
> absence of a MASK map.
> Are the *.series modules a convenient front-end to r.mapcalc?
> Thanks!
> Dylan
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
