[GRASS-dev] Error reading raster data for row xxx (only when using r.series and t.rast.series)
Dylan Beaudette
dylan.beaudette at gmail.com
Tue Oct 13 15:16:17 PDT 2015
Thank you for the clarification Sören.
Any ideas on how r.series could be leaving maps open or otherwise
corrupting inputs in those cases where:
1. there are a lot of maps (>100)
2. method=sum
Dylan
On Tue, Oct 13, 2015 at 12:11 PM, Sören Gebbert
<soerengebbert at googlemail.com> wrote:
> Hi Dylan,
> r.series is a module implemented in C with no relations to r.mapcalc.
> t.rast.series is a Python module that makes use of r.series internally.
> Best regards
> Soeren
> 2015-10-13 21:06 GMT+02:00 Dylan Beaudette <dylan.beaudette at gmail.com>:
>> On Tue, Oct 13, 2015 at 11:55 AM, Markus Neteler <neteler at osgeo.org> wrote:
>>> On Tue, Oct 13, 2015 at 8:43 PM, Dylan Beaudette
>>> <dylan.beaudette at gmail.com> wrote:
>>>> Dangit... This is strange, just did an 'svn up', make distclean, make,
>>>> make install, and now this:
>>>> Welcome to GRASS GIS 7.1.svn (r66487)
>>>> GRASS GIS homepage: http://grass.osgeo.org
>>>> This version running through: Bash Shell (/bin/bash)
>>>> Help is available with the command: g.manual -i
>>>> See the licence terms with: g.version -c
>>>> Start the GUI with: g.gui wxpython
>>>> When ready to quit enter: exit
>>>> GRASS 7.1.svn (prism):~/src/grass_trunk > g.version -r
>>>> GRASS 7.1.svn (2015)
>>>> libgis Revision: 64732
>>>> libgis Date: 2015-02-24 16:54:05 -0800 (Tue, 24 Feb 2015)
>>>> Has it been so long since I have compiled GRASS that I have missed
>>>> something?
>>> Yep:
>>> https://trac.osgeo.org/grass/changeset/65591
>>> "Prevent concurrent raster reads when a mask is present"
>>> (which also got backported subsequently)
>>>> I see that the libgis is still "old".
>>> ... this is unrelated since the issue was in r.mapcalc (hence
>>> affecting all modules using it).
>>> The true revision number of interest is the one next to GRASS GIS
>>> 7.1.svn (r66487).
>>> I guess your issue is now solved.
>>> Markus
>> Maybe. I updated my local copy of grass_trunk last Monday, compiled,
>> and experienced the issues with r.series and t.rast.series... in the
>> absence of a MASK map.
>> Are the *.series modules a convenient front-end to r.mapcalc?
>> Thanks!
>> Dylan
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
