[GRASS-dev] [GRASS-SVN] r66413 - grass-addons/grass7/vector/v.kriging
Vaclav Petras wenzeslaus at gmail.com
Tue Oct 13 20:16:49 PDT 2015
On Mon, Oct 12, 2015 at 6:53 AM, Glynn Clements <glynn at gclements.plus.com>
wrote:
> > Having la.h as a separate header would conveniently hide the compilation
> > issue on that Debian server.
> > So, should I remove la.h from gmath.h?
> I think so.
la.h removed from gmath.h in r66485. I tested that with and without LAPACK
configured. Work as expected. Perhaps the #error can be removed from the
modules if it makes sense to have it in la.h (as I did that).
https://trac.osgeo.org/grass/changeset/66485
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151013/dd11874d/attachment.html>
