[GRASS-dev] Error reading raster data for row xxx (only when using r.series and t.rast.series)
Dylan Beaudette
dylan.beaudette at gmail.com
Wed Oct 14 10:50:53 PDT 2015
Some additional clues:
The original stack was 365 maps with 3105 x 7025 cells.
1. zooming into a smaller region (30 x 40 cells) and running
t.rast.series 100x resulted in 100 "correct" maps, no errors.
2. returning to the full extent and running t.rast.series 30x on the
first 31 maps resulted in 30 "correct" maps, no errors.
3. returning to the full extent and running t.rast.series 30x on the
last 31 maps resulted in 30 "correct" maps, no errors
So, it seems that t.rast.series (r.series) is throwing an error, or
generating wront output, when when:
a large set of maps are supplied as input, and, a region that has a
moderate number of total cells.
Yeah, I know, that isn't very specific. I will try re-compiling with
debugging and no optimization next.
Dylan
On Wed, Oct 14, 2015 at 9:55 AM, Dylan Beaudette
<dylan.beaudette at gmail.com> wrote:
> On Tue, Oct 13, 2015 at 11:58 PM, Moritz Lennert
> <mlennert at club.worldonline.be> wrote:
>> On 13/10/15 20:43, Dylan Beaudette wrote:
>>> Dangit... This is strange, just did an 'svn up', make distclean, make,
>>> make install, and now this:
>>> Welcome to GRASS GIS 7.1.svn (r66487)
>>> GRASS GIS homepage: http://grass.osgeo.org
>>> This version running through: Bash Shell (/bin/bash)
>>> Help is available with the command: g.manual -i
>>> See the licence terms with: g.version -c
>>> Start the GUI with: g.gui wxpython
>>> When ready to quit enter: exit
>>> GRASS 7.1.svn (prism):~/src/grass_trunk > g.version -r
>>> GRASS 7.1.svn (2015)
>>> libgis Revision: 64732
>>> libgis Date: 2015-02-24 16:54:05 -0800 (Tue, 24 Feb 2015)
>>> Has it been so long since I have compiled GRASS that I have missed
>>> something? I see that the libgis is still "old".
>> I've sometimes had to completely erase my source tree and do a fresh svn
>> checkout to get a clean new compile. Not sure why, though.
>> Another thing: you might want to do the make distclean before the svn up.
>> Moritz
> Thanks for the tips Moritz,
> I have tried your suggestion and still get the same errors.
> One more clue in regards to the original "Error reading raster data
> for row xxx" issue:
> * about half of the time the results from t.rast.series are correct
> * the other half of the time I get "Error reading raster data for row xxx"
> * about 1 time in 30 runs the resulting map will be created, but will
> have values at the extreme edges of FCELL precision... suggesting some
> kind of overflow.
> Dylan
