[GRASS-dev] Installing wx.metadata fails
Paulo van Breugel p.vanbreugel at gmail.com
Sat Oct 24 08:55:04 PDT 2015
Hi, I am trying to install the metadata module (on Ubuntu 14.04, GRASS
7.1dev), but with no luck. See error message below. As far as I can see I
have installed all dependencies. I have also tried again after a complete
fresh start (removing the addon folder (.grass7) and fresh install of
GRASS), also without further success, so I am a bit at loss how to proceed.
I have seen a similar message before, but I don't think I have seen a
solution?
Paulo
GRASS 7.1.svn (latlon):~ > g.extension extension=wx.metadata
Fetching <wx.metadata> from GRASS GIS Addons repository (be patient)...
Compiling...
  File
"/tmp/grass7-paulo-18211/tmpcbl2Z1/wx.metadata/scripts/db.csw.admin", line
127, in <module>
    from cswutil import *
ImportError: No module named cswutil
make[1]: *** [db.csw.admin.tmp.html] Error 1
  File
"/tmp/grass7-paulo-18211/tmpcbl2Z1/wx.metadata/scripts/g.gui.cswbrowser",
line 22, in <module>
    from cswlib import CSWBrowserPanel, CSWConnectionPanel
ImportError: No module named cswlib
make[1]: *** [g.gui.cswbrowser.tmp.html] Error 1
  File
"/tmp/grass7-paulo-18211/tmpcbl2Z1/wx.metadata/scripts/g.gui.metadata",
line 38, in <module>
    import mdgrass
ImportError: No module named mdgrass
make[1]: *** [g.gui.metadata.tmp.html] Error 1
Installing...
/usr/bin/install: cannot stat
‘/tmp/grass7-paulo-18211/tmpcbl2Z1/wx.metadata/docs/html/db.csw.admin.html’:
No such file or directory
make[1]: *** [install] Error 1
‘/tmp/grass7-paulo-18211/tmpcbl2Z1/wx.metadata/docs/html/g.gui.cswbrowser.html’:
‘/tmp/grass7-paulo-18211/tmpcbl2Z1/wx.metadata/docs/html/g.gui.metadata.html’:
make: *** [installsubdirs] Error 2
WARNING: Installation failed, sorry. Please check above error messages.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151024/a8c860fb/attachment.html>
