[GRASS-dev] v.rast.stats: ERROR: Input window changed while maps are open for read.
Sören Gebbert
soerengebbert at googlemail.com
Mon Oct 26 02:49:53 PDT 2015
i messed up r.univar implementing a new flag. I will fix it in trunk
and implement some tests for v.rast.stats and a zone test for
r.univar.
Best regards
Soeren
2015-10-24 20:28 GMT+02:00 Helmut Kudrnovsky <hellik at web.de>:
> Helmut Kudrnovsky wrote
>> hi,
>> by testing the manual example of v.rast.stats, I get following error:
>> v.rast.stats --verbose map=myzipcodes_wake at gbiftest
>> raster=elevation at PERMANENT column_prefix=elev
>> method=minimum,maximum,average,stddev,percentile
>> Adding columns '['elev_minimum DOUBLE PRECISION', 'elev_maximum DOUBLE
>> PRECISION', 'elev_average DOUBLE PRECISION', 'elev_stddev DOUBLE
>> PRECISION', 'elev_percentile_90 DOUBLE PRECISION']'
>> Adding column
>> <elev_minimum>
>> to the table
>> Adding column
>> <elev_maximum>
>> to the table
>> Adding column
>> <elev_average>
>> to the table
>> Adding column
>> <elev_stddev>
>> to the table
>> Adding column
>> <elev_percentile_90>
>> to the table
>> Processing data (13 categories)...
>> ERROR: Input window changed while maps are open for read. Map name
>> <myzipcodes_wake_8088.0>
>> Updating the database ...
>> Statistics calculated from raster map <elevation at PERMANENT> and
>> uploaded to attribute table of vector map
>> <myzipcodes_wake>
>> DEBUG=3 output
>> <http://osgeo-org.1560.x6.nabble.com/file/n5232313/grass_cmd_output.txt>
>> tested with
>> System Info
>> GRASS version: 7.1.svn
>> GRASS SVN revision: 66569
>> Build date: 2015-10-22
>> Build platform: i686-pc-mingw32
>> GDAL: 1.11.3
>> PROJ.4: 4.8.0
>> GEOS: 3.5.0
>> SQLite: 3.7.17
>> Python: 2.7.4
>> wxPython: 2.8.12.1
>> Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
> also tested with
> GRASS Version: 7.1.svn
> GRASS SVN revision: 66581
> Build date: 2015-10-23
> GDAL: 1.11.3
> PROJ.4: 4.8.0
> GEOS: 3.5.0
> SQLite: 3.7.17
> Python: 2.7.4
> wxPython: 2.8.12.1
> Platform: Windows-Vista-6.0.6002-SP2 (OSGeo4W)
> same error:
> <myzipcodes_wake_1180.0>
> but it is not in
> GRASS Version: 7.0.2RC1
> GRASS SVN Revision: 66536
> open a ticket
> best regards
> Helmut
> View this message in context: http://osgeo-org.1560.x6.nabble.com/v-rast-stats-ERROR-Input-window-changed-while-maps-are-open-for-read-tp5232313p5232370.html
> Sent from the Grass - Dev mailing list archive at Nabble.com.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
