[GRASS-dev] no grass plugin in qgis installed from osgeo4w
Veronica Andreo veroandreo at gmail.com
Tue Oct 27 08:05:54 PDT 2015
Hi Pedro,
2015-10-27 11:53 GMT-03:00 Pedro VenĂ¢ncio <pedrongvenancio at gmail.com>:
> Hi Veronica,
> Did you install GRASS in OSGeo4W? Which version?
Yes, i got grass stable (grass7.0.2RC) from OSGeo4W 32 bits
On Sunday I made an installation on Windows and I found a problem. GRASS
> 7.0.2RC is already available on OSGeo4W. However, the .bat file that is
> created for the use of GRASS7 with QGIS, does not work, because it points
> to the folder structure of GRASS 7.0.1.
> I don't know if this has been corrected since then, and whether this might
> be your problem. I am forwarding this thread also for QGIS mailing list.
> Ah! So, this might be (one of) the problem(s)... je!
Thanks much!
Vero
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151027/de9e64a7/attachment-0001.html>
